Are u loosing fluid??, if u have to keep adding and u see no leaks then u got a head gasket problem also if its winter and cold where u live then try some card board in front of the radd maby have the thermastat replaced 60% antifreez-40%water mix will do, pure antifreez in the cooling systerm will make it work too effectivly and the motor wont hit operating temp well, but if u dont loose antifreeeezzzz then my bets on the thermastat but try covering the radd infront with card board first only cover one 3dr to one half of the radd after doing this watch ur temp gauge cause i dont know ur climate and how cold its out where ur at HOPE THIS HELPED THANXX!!
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
are you losing alot of coolant out the heater core and making the carpet all wet ? does the coolant lvl drop in the couple days it takes to lose the heat / do a pressure test on the coolant system and see if it leaks. 13 - 18 psi is max if you try it yourself.
