Question about Apple iPhone Smartphone
IPhone Camera Not Working
When I got to take a photo with the camera on my iPhone, it seems to take it and save it like normal. However, when I go to view my photos, they are blank. Example, if I "take" 4 photos, it'll show 4 boxes, where the photos should be, but they're white boxes. It only shows the outline of the box where the photo should be. If I click on one of these white boxes to view what should be my photo, the screen blacks out and goes back to the menu. I haven't had any problems at all with my phone, and I got it in June when it came out. This started happening out of nowhere... it was working fine, then I go to use it again... and this starts. Any ideas on what it could be? And if I go to restore my iPhone through itunes, will I lose all my information... like contacts, texts, etc.? Any info would be appreciated... thanks!
  • 22 more comments
  • Anonymous Mar 08, 2008
    Same thing
  • HOLOGAMI Mar 10, 2008
    same thing.  recent.
  • l1l_l0c0 Mar 20, 2008
    I have the same issue.. happened since I upgraded to 1.1.4 yesturday. Everything else works, including unlocking... very odd
  • sl1120 Mar 25, 2008
    same here.
  • FDZ_CompG Apr 03, 2008
    This just happened to me today! The only thing I did was to download all the pics and select delete all photos after copying. I also bought 2 songs and a ringtone. That's all I did.
  • Nikyboy May 01, 2008
    Hi i unlocked my iphone with liberty 1.1.3 the camera was working fine until i deleted all the pictures taken, now the camera will not open and also the photos gallery. Is there someone out there that can help me.
  • Jontaylor12 May 20, 2008
    I have the exact same problem. I will pay you ONE MILLION DOLLARS to fix it.
  • findcam May 27, 2008
    i have the same problem...exactly
  • macraj May 28, 2008
    when i try to delete pictures from the roll it shows it is deleting but actullay it is not it is there in the roll and when i click a picture an blank box appears in the roll but there is no picture
    Please help
  • Anonymous Jun 02, 2008
    same problemo here. takes the pics but doesn't save the pics.
    do tell...
  • cribbss Jun 03, 2008
    I have the exact same problem!!!
    OK, I took my phone in to the Apple store with this problem. The played with it for a little while and then said OK we will give you a new replacement phone. I synced it with iTunes which copies all my files and setting to the phone. Now the new phone has the same symptoms. Looks like its a corrupted file perhaps? When I do a restore it works fine, until I copy my backup files back to the phone!!!
  • albertbogle Jul 09, 2008
    Its exactly the same problem as Kimberlky
  • Legz Jay
    Legz Jay Jul 12, 2008
  • ericofzzyzx Jul 13, 2008
    I've downloaded all software updates. I tried restarting  iphone. No luck.
  • emmawcox Jul 24, 2008
    My problem is that I take a photo and then it shows the photo as a white box with no photo in it. When I click on the box it goes back to the main menu.
    It was working before and now suddenly not working. Before the camera stopped working the iphone froze one day and would only allow me to make an emergency call- I then uploaded the new software programs and then the phone started working fine- except for the camera function.
  • Anonymous Jul 28, 2008
    Everytime i take a picture it will take it but when i go to my camera roll its just a blank white box. when i click on the white box it just goes back to the menu screen. ive tried turning my phone off for a while and then turning it back on but its not helping it. what else can i do exactly.
  • Anonymous Aug 10, 2008
    Spontaneously my iPhone went from taking pictures to not completing the process.  The phone clicks when I take the picture- but in the spot where the picture should be- it is blank.
  • beautyismear Aug 11, 2008
    Yes I have the same problem but I'm afraid to do anything because my phone was Unlocked........!!! So I don't want to mess up and lock it back. Can anyone help me please ???
  • ppus Aug 28, 2008
    i have similar problem when i open my camera appears a black screen
    and returns to the menu pls let me know there is any solution
  • Anonymous Oct 11, 2008
    i have the same problem. when i take a picture the iphone is not saving her. i don't know why
  • bubbles111 Nov 06, 2008
    Same problem...white boxes...crashes when you click on it. Also the computer doesn't let me access the drive anymore. Anyone got any clues on how to fix this?
  • MalPortada Mar 03, 2009
    Hi I have a proble because the phone do not conect to the earphone... when I plug in--- ? What can I do? Model P168s
  • Brandon Carr May 11, 2010
    What firmware is your phone running on, and have you recently upgraded/downgraded it? If so, from what version?
    If you restore through iTunes, your information will be backed up on your PC, and you can put all of your contacts back.
  • Ok I found the solution to this problem. This is what worked for me.
  • Apparently the problem lies in a hidden folder called  .MISC under
  • SSH/MobileFinder to Media/DCIM/
  •  (if you are using MobileFinder, make sure to turn on "invisible files" in the settings)
  • Delete this folder which contains the preference file for the camera and the poster picture for the camera's album thumbnail.
  • Try taking a picture again and it should work fine now.
Posted on Nov 06, 2008
I was having the same problem and tried several solutions. The only one that worked was the simplest. Use a program such as WinSCP or CuteFTP to SSH into your phone (there are lots of guides on how to do this) Then navigate to /var/mobile/media/DCIM and delete the two folders that are there. THIS WILL ERASE ALL OF YOUR CAMERA PICTURES, so if you dont want to lose them back the up first. Then if you want you can add your backed up pictures back to the phone. Hope this helps some of you not have to do a full restore
-joey
Posted on Mar 16, 2008
Living with an iPhone I have came accross a few problems that all relate to the device not saving data input. The camera not saving pictures taken is one of those problems. Another is related to not being able to change email account details on iTunes and have that reflected on the iPhone.
There is a common solution that solves these issues quickly, for jailbroken iphones. Install BossPrefs from Cydia. Access that application then click on the "More" button located at the top right of the main screen. A list of functions will appear. Click on "Fix User Dir Permissions". This solves these types of problems every time.
Hope this helps.
Posted on Jun 21, 2009
    Sniper:
  • 62 Answers
Restore your phone to the latest firmware (1.1.3 as of this writing). Your data is stored on your system so you won't lose anything. If the restore does not fix your problem, you will need to take your phone in for work under warranty.
Posted on Feb 19, 2008
When unable to use the camera, with this message "There is not enough room to take additional pictures. Please delete some existing photos.", when you know there should be enough space on the iPhone. Try this: Connect iPhone to iTunes, Click Restore and follow the process. After the phone is re-listed in iTunes, answer the prompt to restore all your data. Worked for me.
Posted on Nov 10, 2008
Here's also a guide to help you fix iPhone camera problems.
How to Fix iPhone Camera Not Working
Posted on Feb 27, 2017
When ever you are having problems and restore an iPhone you should always select "Treat as new" when connecting with iTunes and not "Restore Backup" as that can just put the original errors back onto the iPhone.
I have never heard of this problem in all of the over 500 iPhones I have unlocked and given support too.
But if I had to guess I'd say go with Solution #3.
Good luck.
- Dr.iFone
Vancouver, B.C.
Posted on Jun 04, 2008
My Camera would take the pictures, but when I went into 'Camera Roll' they weren't there. I used WinSCP to connect to my jailbroken v1.1.4 iPhone via openSSH. I then navigated to the directory mentioned in Soultion #1 by jch0075 [ /var/mobile/media/DCIM ], and set the permissions on it, and the two within it, to 777 for each (right-click in WinSCP and type '0777' in the 'Hex' box toward the bottom). I then Opened camera, took a picture, saved fine, still had all my previous pictures, didn't have to restore.
Posted on Mar 21, 2008
My iPhone camera cliks a photo show in counting but does not goes to the photo libary. Kindly give assistance where the photos go or what do.
Posted on May 30, 2010
There is no options like night mode as in other phone so dat i can take pics in the night. im using a 3GS i phone
Posted on Apr 06, 2010
I have a little problem when switch on my camera it takes green photos any help would be appreciated.
Posted on Jan 03, 2010
I had the same problem. I downloaded snapture using the installer program. After intalling this program and taking a few pictures I was surprised to see the camera also worked perfectly.
Posted on Sep 06, 2009
When switch on my camera a message pops out saying "There is not enough room to take additional pictures. Please delete some existing photos." when I say ok and go to the camera roll, there is isnts any picture existing, and I have around 6.30GB space left in my iphone.
Basically I just cant use my camera.
Any solution??
Posted on Oct 26, 2008
    Problem Solver:
  • 5 Answers
  • 20 Answers
I am having the same problem
Posted on Sep 08, 2009
It does not turn off at the set work pressure?
Sony Cyber-shot DSC-W5 Troubleshooting - iFixit
https://www.ifixit.com/.../Sony_Cyber-shot_DSC-W5_Troubleshoot...
iFixitCamera Won't Turn On; Power Turns Off Suddenly; Replacing Battery Terminal. Display ... If that doesn't work attempt to give the camera a good jolt. A shake of ...
D700 Control Panel Won't Turn Off - Photo.net Nikon Forum
photo.net > ... > Forums > Nikon > Nikon Digital - Cameras and Scanners
May 28, 2013 - 17 posts - ‎9 authors
Setting c2 is set to value = no limit. Maybe? ... Does the AF work normally with a halfpressure on the shutter button? In any case the top LCD ... As long as the camera isnot shut down, this is completely normal. This is like this ...
iPhone 5 Camera Not Working? Fix Your Problem ' ISeen Lab
www.iseenlab.com/fix-problem-iphone-5-camera-not-working/
May 17, 2015 - Let's go though iphone 5 camera not working black screen. ... Virus Problem : This problem can disable your phone whole system. ... Light Pressure : This will occurs when your iPhone 5 had hardware problem. ... my iphone 5 front camera is working but rear camera does'nt work show the blank screen.
Rear camera stopped working after iOS 7.1.2 upd... ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple
Jan 20, 2016 | Cameras
How do I transfer iPhone 4S WhatsApp photos to my PC?
first save all the photos to camera ( long press on picture save to camera)
then connect phone through usb thrn open my computer open iphone folder save picture to your computer.... 25208898-xxg23bqogrpujztq43hjzuo2-1-0.jpg
Or you can download Backuptrans iPhone WhatsApp Transfer to help. It lets you transfer and manage your WhatsApp chat messages on computer smoothly. Restoring WhatsApp chat history from computer back to your iPhone is also supported.
Oct 11, 2014 | Apple iPhone 4S
Transfer pics from my iphone4s to my iphone5s
You can make it by simply connect two iPhones to the PC, and download an app named AnyTrans to transfer all or selected photos from iPhone to iPhone. How to Transfer Photos from iPhone to iPhone
Oct 06, 2014 | Cell Phones
Camera will not transfer to iphone or ipad after last apple update 8.0 but did before. What setting got screwed up? Camera is Samsung WB350F
I'm not familiar with Samsung digital cameras. How did you initially transfer photos from camera to iOS devices? Is it possible to save the photos on your computer and then transfer them to iPhone/iPad via iTunes? How to Transfer Photos from Computer to iPad
Sep 24, 2014 | Samsung Cameras
My instagram photos will upload to the feed but not save to my profile
Open Instagram settings. Tap the Profile icon in the bottom right corner of your iPhone.
Tap the gear icon It's located at the upper right of the screen.
Scroll down to the bottom of the Options page. Enable Original Photos. This will save your original images to your Camera Roll. High resolution versions of the filtered photo are also saved to the Camera Roll.
Note: both original and filtered photos are automatically saved to your phone. The originals are saved in the Camera photo album, and the filtered versions are saved in the Instagram photo album.
Sep 22, 2013 | Computers & Internet
How can I transfer my photos from private pics to the camera roll on my Iphone?
The camera roll is a place where all your new pictures go. You cant transfer things back into the camera roll without a ton of effort. You could save the photos to an app and then when you save them back, they will be in the camera roll but im pretty sure you would have to do this for each individual photo.
Jan 13, 2011 | David Earnest Private Pics
Can i retrieve deleted photo
First take the memory card out of the camera. Pictures that have been deleted are probably still there, but will be overwritten if you take any more pictures on top of them.
Your camera is not able to undelete pictures, but there are programs for doing this on a computer. You can put the memory card into a card reader attached to a computer, and use an undelete program to recover the deleted files. Undelete programs are available for free download from the internet, try at www.download.com.
If the pictures are very important to you, you might want to seek help from an experienced person.
Nov 16, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Photo taken by iphone camera doesn't appear on iphone library
Download iFun-Box and you can browse your intire iphone filesystem, and u can get the photos you captured
Oct 16, 2009 | Apple iPhone Smartphone
IPhone camera stopped working
My iPhone camera stopped working.i press the cam widget and the shutter appears closed.
Sep 15, 2009 | Apple iPhone Smartphone
What do i need to do to delete the iphone photos ?
2 ways:
1. When you click "import photos" while syncing your iPhone it asks you if you want to keep the originals or delete them (meaning on the iPhone). Just click delete originals
2. Go into your iPhone and clear all photos.
Jun 09, 2008 | Computers & Internet
Apple iPhone Smartphone Logo
29,265 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
