I have an RCA model Number 32F531T. It was working fine ad then it ceased to have apicture or sound. Could it be the fuse and if so where is the fuse located so that I can order another one and have it replaced. If it could not be the fuse do you ave any idea what could have caused the problem? Thank You for your time and I hope to hear from you soon. Michelle
  • 5 more comments
  • rezcookie Feb 17, 2008
    No picture no sound...The green light comes on like there is power but none seems to be going where it needs to
    Nothing is showing on the screen. No picture, no menu. no nothing. Not even the snow is showing. I will try to unplug for four hours and see what happens. We havew a lot of power outages where i live could this cause a malfuntion? Could it be a fuse? If so where is the fuse located?
    I think I need a lot of luck!
  • rezcookie Feb 18, 2008
    Thanks for your help, I will try to find the fuse. We live far from any repair person.4 hours or so to be exact so hopefully we can fix it by getting a fuse. What would cause the signal board to go out?
    Michelle
    What do you mean...The electricity going out on and off? I live on the reservation far from anything. I usually have to fix whatever is wrong myself but i guess I will have to wait on this one and see if I can get it to a repairman..Is it even worth taking in? How much would you assess it to cost? We paid 700.00 for the Tv and have just now barely paid for it. We bought it to help a lady so she could move away with her kids..So much for good deeds!
    LOL
    Michelle
    Not worth it is it? I think you can get a HDTV mybe not as big but big enough for the same cost..
    Michelle
    I just went to find the fuse and couldn't but when I did I noticed that the on off switch was not turning off.( the green light is on all of the time) Could it be the switch not engaging? The green light is staying on nad you can hear it try to connest but I don't think it is. How could I fix the switch. Would I need a new one if that is the case?
    LOL I guess it is not a laughing matter but it is funny isn't it? Thank you for everything. I appreciate your help. Is there a specific place I can go for parts. I tried to look but I don't know the parts #'s. I know some sites if you put in the model; # it will link you to the right part for your appliance.
    I figure I took up a good part of your day and will leave you alone after this. I sure wish the first suggestion of slapping it around a little bit would have worked..I would be all to happy to give it a wack or two!
    Genius:
  • 3,422 Answers
You mean there is no picture and sound or is it just that there is no sound??
Posted on Feb 17, 2008
  • 9 more comments
  • Priya darshan Feb 17, 2008
    ONE: This is an RCA set. Not a good thing - in my humble opinion. They are not a reliable brand.
    TWO: The set is old enough that you should always keep in mind the
    question of repair or replace. Since it is an expensive set, it should
    return the investment to you; on the other hand, if the cost of
    maintaining it gets out of hand it would have been better to put that
    into a new set with better prospects. This can also be a transformer failure.
    THREE: SO, lets now consider the symptoms of your set. The fact that
    cable channel guide data is showing on the screen means the basic video
    system is working. That means the power supplies and high voltage are
    in place.
    FOUR: You could be in video input and there is no video and the set is
    working just fine. So, we must verify the cable box or cable wiring is
    giving you the right signals. The best test is to switch the tv to
    video in and play a vcr or dvd through the tv. If you are getting full
    picture and sound then the tv is likely not at fault.
    FIVE: If you have another tv in the house, try connecting it to the
    same cable wiring to see if it receives the cable programming. If not,
    then the problem is wiring or cable box. If it does, then the rca may
    be at fault.
    With these checks above you should be able to determine whether or not
    the tv is at fault; wiring or settings on the tv. Then take the
    appropriate actions. If the tv is truly at fualt, you will need a
    repair tech to look at it, again.
    You know, I have seen a case exactly like this and the problem turned
    out to be a short in the cable coming out of the junction box on the
    wall. I opened up the box and found a short against the metal box;
    moved the wire around and cleared it, put some insulating tape on the
    end of th cable and it worked just fine.
    Not that this is the cure
    for yours, but the point is that sometimes the problems can be quite
    remote from the tv set itself. That is why I asked you to check and
    verify so you can learn where the real problems lie.
    Here are few more trouble shooting steps you can try:
    ONE: Disconnect the power cord for 4 hours. Then when you power it back
    up the internal soft codes will automatically reset to factory defaults.
    TWO: The whacking test is to just bang or smack the set with your hand
    on the back, side, top, etc., to see if there are loose connections or
    cold solder joints inside that are acting up. If so, the banging should
    knock them back to normal and the set should restore. You might have
    to use some creative banging and some have had to put a book or
    magazine under one corner to torque the chassis enough to get it to
    work reliably.
    Goodluck..
    Hi again,
    it may be the fuse also but since you have no power and no sound then the problem is with transformer and other convergence which is inside and can only be fixed if you get it repaired.
    Goodluck again..
    this is can also be possible If No video, No audio and has the green light yet could be IC's on Large signal board, IC7402, IC7410 and IC7412
    (board APD28C003) board replacement would be advised
    For the fuse try looking in the power section some TV is located near the on/off switch.
    Please ignore the IC no. which i gave you because it is not for ur model no. But the board replacement thing is advised to be replaced.
    I would suggest you to call a technician and get it repaired.
  • Priya darshan Feb 18, 2008
    It is the bad power supply..
    the cost of repairing it will be between $300-$400.
    That is all i can say..
    I already told you that it is not worth.. please read my points one and two.
    i can say that the cost of repair should be around $300 if there are not too many problems wid it..
    Anyways make ur choice. repair or replace..
    I suggest you once try replacing the fuse..
    then go for a repair if it doesn't fix the problem
    Well i suggest you to replace the switch as well as the fuse.
I have sound but no picture on my rca 32f531t
you can have these guide:
Flyback Transformer
the horizontal output transistor is for ITC008
search these site you can find more info for your chassis
that was 2 years ago
Sep 28, 2012 | RCA 32F531T 32" TV
How to unlock RCA 32F531T 32 '' tv. I tried the manual solution but didn't work.
You might have to enter its service mode option to unlock it. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
Aug 13, 2012 | RCA 32F531T 32" TV
I need to know the datasheet for the horizontal's transistor for a tv RCA 32F531T, because I lost the replacement
Hello
The number of horizontal output transistor is [TL 035]. If this number is not available, you can use exact substitute after reffering it to transistor data book and equivalents. OK.
Jun 03, 2011 | RCA 32F531T 32" TV
RCA TV wont come on
if your tv 52" silverish color hd model,problem is on power supl.deflection module(module is on left hand side),famos for number of problems,importent to indicate if green light on front panel comes on and goes off in 3-5sec.if not tv has bad fuse(put 8 amp) if blows as soon as plug it in-bad diode on the same with fuse module.
Jun 10, 2009 | RCA 32F531T 32" TV
No sound
You might want to double check all of the audio settings within the menu to make sure is it not in the SAP mode (Second audio programming). Also make sure it's not selected to ext speakers.
Apr 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA F32650 no picture
Sounds like the flyback. Mine did the same. I am in the process of trying to fix it. Try techlore.com for more help.
Jun 24, 2008 | RCA 32F531T 32" TV
Rca f27450 TV
It sound like your set have dryjoints
Oct 11, 2007 | RCA 32F531T 32" TV
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
