Question about Siemens WFXD5200UC Front Load Washer
Water Does Not Drain
The washing machine fills with water, it spins , it does not drain the water after the cycle has ended. (error code E:04)
  • 1 more comment
  • ermedic Feb 17, 2008
    Thank you very much for your help, I recently had the door gasket replaced by a service company, I complained after the repair was complete that the door was not in alignment and it had to be physically lifted up to close the door. The repairman told me that this was due to the new gasket was not molded to the door like in the factory, and it would be a year before it closed properly. Is it possible that this miss alignment caused the door control to fail. I made an error in my model number it is WFXD5201UC , Thank you for all your help
  • Anonymous Mar 30, 2014
    Error code E3....got it to drain water but will not spin clothes.
  • 770 Answers
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
Posted on Feb 17, 2008
E04 problem you dont need a tech. If your gasket ever ripped while doing a load probably a piece on clothing got in and found its way to the pump that drains. This could be a few years down the line that this will block the water from exiting.So heres what you need to do to get it out.There is a round cover on lower right corner in the front of the machine. turn the cover to align with the 3 latches that keep the cover on or just pry it with a screw driver. Inside there will be a black cover that you need to turn by hand to unscrew it. Yes this water is the drain water and it doesnt smell great. Water will start coming out when you start turn this black cover so have towels around. Once its open stick you hand in and you should find some clothing that is blocking. Thats it make sure nother is left behind like a little cloth that got ripped from the turning pump and it in the turning part of the pump. Know you just save the service diagnostic charge and what other bs they would have said.
Posted on Mar 23, 2011
We have a Siemen's front loader washer. Today, it showed an E04 error. In the past, when this was the result of too much soap, it could be cleared by adding some fabric softener mixed with water into the soap dispenser and starting the washer over again.
However, this time, the washer wouldn't drain or spin. We tried clearing the drain hose from the washer to main drain and that didn't help. After reading some helpful posts, including the one above, we decided to check the pump filter.
owever, since there was still a lot of water in the washer and we couldn't open the door to drain it, we had to try a few things. First---we unplugged the washer.
We removed the round cap on the front lower part of the front of the washer (it twists off) and found the black pump filter cover. We used a flexible plastic funnel (with a notch cut out so we could get our hand in) and slowly turned the filter cover. The funnel helped to direct the water into a bucket. (Our washer is on a pedestal, which helped.) There was A LOT of water to drain (3 buckets, 3/4 full). When draining was complete, we removed the filter and found a few things that were likely the cuprits. We put the filter unit back in snuggly and the washer again worked.
Posted on Sep 17, 2012
Can you tell me what error code E12 is on a Bosch vision 300 washer?
I am not quit sure if my answer will help you, but I am going to tell you the cycle
The unit fills to whatever water level you choose to use
After reaching the water level the the wash begins, after 20 or 30 minutes of washing it needs to drain the soapy water. The drain pump turn on draining the water, after draining the unit fill back up to the settings and or sprays water while doing the draining and spinning to remove as much dirty water as possible from the first wash. After the first draining, fills back up again for the final rinse and the final drain
The symptom you are describing, here tell me, that issue is with the drain valve, drain hose, the sewer, or is a big possibility that there is is a sock or woman garment stuck in inside holding the rotor causing the water not drain inside the water valve, if the sensors are not sensing the opening of the pressure switch after the first fill. it will not continue This units lately has been added many sensors the only thing this unit doesn't has is the ability to speak but if using common sense you can get to the part that needs to be replace. You need to read and understand the wash cycle first.
Nov 24, 2017 | Bosch Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
When my cycle is done my washing machine read sd
Hello, W/D here.
Sd is the error code for suds lock. If suds are detected continuously by the pressure switch during the
drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again. The SD code indicates the possibility of too much detergent being used. Run a rinse and spin cycle to remove detergent residue. Then run a normal cycle without detergent.
Items to check if it is occurring at the end of the cycle would be to check the drain line and waste outlet for plugging or kinks and check the wiring harness connections to the drain pump, pressure switch and CCU (Central Control Unit). It may be necessary to check and clean the drain pump filter.
Best regards, --W/D--
Feb 15, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Siemens WFXD5200UC Front Load Washer Logo
1,780 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
