NOT ABLE TO GET PRINTER TO PRINT
I HAVE A BRAND NEW HP OFFICEJET 4300 ALL-IN-ONE SERIES. I CAN USE THE COPIER SCANNER AND FAX,BUT WHEN IT COMES TO THE PRINTER IT WILL SAY OFFLINE PRIINTING AND NOT PRINT AT ALL IT WILL SAVE IT UNDER PRINT JOB
  • 1 more comment
  • patsymat Feb 21, 2008
    I have this same problem.
    as suggested, I went to the printer menu and made sure that Print Offline was not checked. No change...still no print job.
    I know this will sound weird, but I THINK this printer worked until about 1 month ago. I have several printers and this one is fairly new. It may never have printed...I use it primarily for faxing and scanning.
  • Anonymous Apr 04, 2008
    My HP Officejet 4315 All-in-One is offline and I am unable to get printer back online. I have already disconnected and reconnected cables. I have clicked online button. Printer still reads as offline and not ready to print.
    I have even shut the printer and turned back on again.
  • ANNEB1 Apr 14, 2008
    I HAVE THE SAME HP ALL-IN-ONE PRINTER AND WHEN I ATTEMPTED TO PRINT A DOCUMENT I HAD A PAPER JAM. I REMOVED HE PAPER, AND NOW IT SAYS THE PRINTER IS OFFLINE.
  • 64 Answers
If you open up the printer (start => settings => printers and faxes..), and look under the "printer" menu, is "use printer offline" checked? If it is, un-check it.
Posted on Feb 18, 2008
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
OfficeJet 4315. When receiving faxes, why does it print blank pages?
Hi Ljiljana Tubic,
I would be happy to help you with your Officejet 4315. I understand your faxes are printing but there is no ink on the page. I suggest using the following document to troubleshoot the issue:
HP Officejet 4210 4250 and 4300 All in One Printer Series Correcting Print...
If the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 28, 2015 | HP Office Equipment & Supplies
HP Officejet 6318 displays "reset
Go to this LINK.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | HP OfficeJet 6310 All-in-One Printer...
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 4300 officejet canot print from system command but they working fax incoming and out going and copying solve my problem
you have a problem in the computer,delete the hp 4300 from the printer menu on the computer,download from hp.com the latest drivers for your printer and Reinstall it.
Mar 09, 2010 | Office Equipment & Supplies
"Scaner Failure cannot copy, scan, or send fax" warning from my hp officejet 4300..can you all help my problem thx :D
as this printer is connected through a print server so how can i use the scanner through network
Jan 14, 2010 | HP Officejet 4355 All-In-One InkJet...
My HP officejet 4300 series stopped printing and shows that it is offline. How do I get it back online?
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
Aug 04, 2009 | HP Officejet 4315 All-in-One Printer
When I click the print button, a fax window pops up, and it will only let me fax, and not print
In Windows Xp
Click on start and click on control panel
in control panel look at the top left and switch to classic view(unless your already in it,if ur in it then u'll see a lot of icons and not groups)double click the printers and faxes folder.
now look at the tow icons of your printer and one will say officejet 4300 series and one will say 4300 series fax.
right click the 4300 series and select set as default.
Now click on print if you still get the fax window select your printer icon in the drop down list and then the fax window will not popup.
IN VISTA
Click on the start button and in the start search box type "printers" and press the enter button.
In the printers window single left click the printer icon(4300 series,not 4300 series fax)
Then single right click the 4300 series icon and select set as default.
now close the window and try to print if u still get the fax popup then selet your printer icon in the drop down menu and it will print and not fax
Jun 25, 2009 | HP Officejet 4315 All-in-One Printer
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
666 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
