Question about Samsung Digimax L730 Digital Camera
When I turn on, picture view is fuzzy, cannot take a picture, bleeps three times then turn off, have tried fully chargin battery, reseting and formating, had camera 3 months, this is the first problem I have had.
  • 5 more comments
  • ketkanok Apr 15, 2008
    samsung L730 had it for only a month haven't done anything to it then one day i was taking picture when i turned it off and turned it back on again the picture was all fuzzy at first thought the battery was low but when i fully charged it still the same problem it bleeps and turns off too.
  • won_ton_ Jun 26, 2008
    Bah, i have the exact same problem,any solutions?
  • Anonymous Jul 04, 2008
    Yes I have the same problem
  • ladylailey Jul 10, 2008
    The same has happened to me too and its driving me mad not being able to use the camera. Can someone PLEASE suggest how we can fix this, I've only had my camera since March
  • xGHERKINx Aug 11, 2008
    I am having exactly the same problem. Anyone found a solution yet?
  • Anonymous Sep 05, 2008
    I have the same problem, haven't had it long.
  • Anonymous Sep 14, 2008
    yep me too same problem
    can it be fixed?
This problem is usually caused by grit in the mechanics of the lense. To resolve the problem:
1. Ensure the lense itself is clear, removing any visible objects.
2. Try tapping / knocking the camera to dislodge any obstruction.
3. Failing this you can force the mechanics by turning the lense sections - however be careful when attempting this as you may snap the lense if turned too hard or the wrong way.
Words of wisdom from: Malhotra, Manmohan
Posted on Nov 05, 2008
Got the same fricking problem. no more samsung anything for me now!!!
Posted on Oct 16, 2008
I encountered this issue today while taking a photo of my dog she licked the lens... the LCD screen went all blurry and I was unable to take any photos. The thing kept beeping at me and I was about to throw it in the bin until I had a good look at the lens. As there was a picture coming through on the LCD I knew it wasn't completely stuffed however as the camera couldn't focus an image it gives the unhelpful beeps which apparently translates to clean the lens! So i gave it a clean and presto it was fixed!
Just be careful when u clean it make sure u don't scratch the lens with rough material or use chemicals. Hope it works.
Posted on Sep 17, 2008
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
Selected format and pictures disappeared from Samsung L730 camera
Format completely erases the card and optimizes it for your particular camera.
Sep 13, 2009 | Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Samsung L730 camera. Is fully charged. Power button is permanently on. Lens locked - can't move in or out. No display
take out the battery wait for a few sec and then put the battery back on, then switch the camera on.
for the lens try to gently force open or close the lens.
this works on my camera. i have the same problems. hope this helps.
Dec 03, 2008 | Samsung Digimax L730 Digital Camera
Camera just won't turn on!! :)
Katie take it back to where you got it places like best but some time will just give you another camera no questions asked.
Apr 19, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
321 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
