Question about Brother XL-3500
Stitches i am having problems setting my stitches right please help
  • Anonymous Feb 19, 2008
    Modern sewing machine very good condition, shiny material like polyester, when stitching I find that when finished sewing ,you can move the material along the stitching although the stitching is good. Can you help as to why this is happening.
    Wendy
  • Wendy Nabors
    Wendy Nabors Jun 03, 2008
    i am having problems setting the lower tension. it is really loose.
  • Brother Master
  • 1,388 Answers
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
stitches - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
Hi, I have purchased an adjustable blind hem foot for my Classica 90. Would you please advise what the setting for blind hemming is on the sewing machine is? I cannot locate it. Thank you.
Perhaps this video will help:
How To Sew Blind Hem Stitch 2
Unfortunately, after reviewing your machine's manual, your manual does not indicate that your machine provides a blindhem stitch. The blindhem stitch generally is a stitch that takes several straight stitches and then zags to the left to catch the garment fabric. You can, however, use a zig-zag. You will just have more stitches into the garment that may show on the right side.
Aug 23, 2015 | Husqvarna Sewing Machines
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
Singer 2662 only does a straight stitch
got the same problem - wish I could help you -
Jan 13, 2010 | Singer 2662
Problem with Brother XL-3750
can u chart me on whatsapp +2348189956612 so that i can help.
Oct 03, 2017 | Brother XL3750 Mechanical Sewing Machine
Thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Oct 20, 2008 | Toyota TL-432DE Mechanical Sewing Machine
Quilting seam allowance
When you turn your machine on it automatically sets up for a straight stitch with the needle centered. Just guide the right edge of your fabric along the line marked 15 on the throat plate and you'll have very close to a 5/8" seam. If you need more precision you can adjust your needle position to the left or the right by using the stitch width and mirror setting buttons.
Jun 23, 2008 | Husqvarna Rose
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Brother XL-3500 Logo
87 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
