What is the correct cd auto changer for the kenwood kvt m700 also every time i turn the unit off i have to use the mask key is this normall and how do i turn it off
Bu the sounds of it, you will only need to enter the mask code if the memory wire becomes disconnected, so I would assume that you have your power(red) and memory/constant 12v backword, or both hooked up to the power wire
Hi
Guess your car's wires haven't been cut. Go to any stereo shop and get the harness that's specifically for your car. The colors on it will match all the colors on the clarion harness. Connect like colors, plug in, and you're done. Please check the below mentioned site for the wiring diagram which will help you for the installation. http://www.tehnomagazin.com/Auto-radio-car-connector/KENWOOD-Car-Radio-Wiring-Connector.htm
please let us know for further query.
Thankyou for contacting fixya.com.
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
The only way to play DVD's on your M700 is to have the handbrake on. Although you can get round it by plugging the DVD into the second set of connectors (AV2) instead of the first (AV1).
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
you need a mask key, it is a type of code, you need to use it if you disconnect from the live. There is a company on ebay where you can post your kvt m700 off to and they remove the code so you don't need the mask key any more. I don't know if they are reliable or not, you will have to look into it.
The kvt-617dvd doesn't list your changer as one that's compatible. However the changer install procedure is relatively simple - just plug the 13-pin cable from the changer directly into the kvt-617's hideaway receiver. I would suggest you connect it to see if the changer will work before buying anything else.
