Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Dishwasher's cycle just stalls
When i attempt to run a cycle on my dishwasher it stalls. I've checked for power and that seems to be find. After unplugging the unit it resets. When I push the buttons for the functions i want ( normal, sanitize and hi temp) the dishwasher excepts the settings and begins running. I can hear water running and air coming out of the air gap. The unit runs for 3 minutes and then goes silent. I looked thru the manuals and the troubleshooting guide sucks! Can't seem to find a wiring diagrahm either please help.
  • Gary Davd
    Gary Davd May 11, 2010
    is the water turned on to the unit??
    Genius:
  • 1,665 Answers
It looks like you have a cold water supply problem. Check water entrance pipe, may be bend (if you have there a vane - see it is open).
Check that water entrance valve work (it is an electromagnet valve,located at the pipe's enterance to the machine).
If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnected the power cable from machine before doing it.
Check as well for valve's coil resistance or you should replace for a new valve.
Posted on Feb 17, 2008
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Not draining
Are you sure your drain system is not clogged or restricting water flow ? When you say youtook off the hose off under the sink and it seemed to be lots of water running on the rise cycle .. that suggests that you may have a restriction after the drain hose in your house drain system. ...
Some other considerations..
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used
Hope this helps you...
Sep 03, 2008 | Dishwashers
Frigidaire stalled dishwasher
do you here any relays or the motor run? if not perhaps the fuse or circuit breaker has opened.
Mar 28, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
228 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
