Question about NuTech QL-711V 17" Flat Panel LCD Monitor
NuTech QL-711V Monitor - no picture
The unit powers on, but does not show an image. Possible backlite failure? Any suggestions?
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
I connected an external monitor to a lap top. The screen on the monitor is bouncing making all the print fuzzy and difficult to read.
Have you tried the same connection with another monitor? That will tell you if the cable or monitor is the problem. If the same thing happens with another monitor then its the computer input or system drivers.
Dec 31, 2013 | Computers & Internet
As soon as i turn it on it shows the picture for an instant then goes black. u can barely see the image when u look at the monitor at an angle. any suggestions....
This is a failure of the circuit that runs the fluorescent lamps that light up the screen or possibly a bad lamp, I have seen both types of failure occur. It is possible it can be repaired but if you take it to a shop the repair can cost a significant portion of just buying a new monitor. I repair some and toss some depending on the economics of each case individually.The lamps are too much trouble to bother with, and the power circuits can be both simple and complex depending on what part failed.
Feb 14, 2011 | Westinghouse LCM-19v5 Monitor
Have lost the remote to my Nu Tech TV. Where can I get anew remote?
try their web page if the parts you need are not there you can use a universal remote or you acn also try ebay or a different online store
Jan 16, 2011 | NuTech QL-711V 17" Flat Panel LCD Monitor
My monitor is no longer working when plugged in into the wall it just flashes like the boot of the monitor and then make a small cherp and just repeats over and over again. Can you tell me what wrong and...
Does it do the same when it is hooked up to another PC?
If it is monitor problem, then please read on before DIY repair.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | NuTech QL-711V 17" Flat Panel LCD Monitor
Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
May 24, 2010 | ViewSonic Graphic VG2021m LCD Monitor
My fpd 1730 moniters brightness and contrast are terrible, and i cant get the controls to work
nonnie707, It is very possible that your monitor's internal or external (lay on floor) "switch-mode-power-supply" has a problem. Prove that your pc is working by connecting KNOWN GOOD monitor to your pc!!! If you are not electronics technician then you will need to question Gateway as to warranty service or possible swapout for a REFURBISHED unit if your unit is deemed as premature failure. May cost $ for swap. READ my FIXYA profile and that of other FIXYA TECH's (buddymc, budmrtn) for more options as to "what to do"!!! Remember, If very strange and weird things start to happen (occur) with "cold-cathode-fluorescent-lamp" backlit LCD display, the first place I would investigate would be the units "switch-mode-power-supply" Good luck with the repair. 12fixlouie
Feb 02, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
I have somehow locked my Nutec television and do not know how to unlock it
Push and hold the Power Button for 15 Seconds. Should unlock you set.
Dec 24, 2009 | NuTech QL-711V 17" Flat Panel LCD Monitor
I have a Samsung SyncMaster 931c monitor (2.5 yrs old). Sporadically during the last month, I'd lose the screen image and get vertical stripes on the display. I'd turn the monitor power button off and on...
jcacolice, Most likely your 931c will need work done on it. When strange things start to occur with any LCD CCFL backlit display I would suspect the "switch-mode-power-supply" first thing!!! If unit is out of warranty you or someone will need to inspect and troubleshoot it. A good place to start will be to see some DIY videos on YOUTUBE. Try search of "lcd monitor disassembly" and "lcd monitor repair" and learn all you can about the TOP CAUSES of monitor failure. Then visit (FYI) www.ccl-la.com/badcaps.htm and www.badcaps.net for more info. Explore ALL your options before you do anything. Then get back to us here at fixya if you still need some asssistance. Read some of my other responses in my fixya profile and other those of other tech's on fixya.
Hope to see you back on fixya with a plan of action!! 12fixlouie
Dec 23, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Monitor goes black after 5 seconds but has power.
Power Supply inside the monitor is bad, needs replaced. Compare cost of replace or repair. Usually best to just go get a new monitor.
Mar 17, 2009 | HP Compaq FP5315 15" LCD Monitor
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
NuTech QL-711V 17" Flat Panel LCD Monitor Logo
309 people viewed this question
Top NuTech Computers & Internet Experts
David Payne
David Payne
Are you a NuTech Computer and Internet Expert? Answer questions, earn points and help others
