Question about Linksys Wireless-G WRT54G Router
Connection I installed a new router and the only way I can access the internet is if I by pass the linksys
  • wardn877 Apr 30, 2009
    When I connect my computer to my DSL modem DHCP provides an IP and subnet mask, 2 DNS addresses and everything works. I have to make my router spoof the computer mac address before the router will get an IP from the modem but it works. My computer gets an internal 192.168 IP from the router and reports being connected but the browser never reaches any webpages. This failure occured while no one was around but there are no indications of a general power failure. My next step is to reset the router to the default and try to reconfigure it.
  • 89 Answers
I had the same problem with a TP-Link wireless. I made connection first with the computer hooked to the DSL modem. Brought up a browser and made sure I was on line. Then connected Modem to router and router to computer. There were pop-up messages to let me know when Cable was unplugged and when connected was made again. I then stayed connected, until the electric went off and immediately back on. So had to go through it again to reconnect. Hope this works for you. Thanks
Posted on Feb 18, 2008
5 Suggested Answers
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses,, however sometimes the wifi is setup, or etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look.
Posted on Aug 05, 2007
  • 73 Answers
SOURCE: Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Posted on Apr 13, 2009
  • 9 Answers
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range..., and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the range.  A valid private IP address is typically in the range, but could also be in the range, or the range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Posted on May 01, 2009
SOURCE: Error 322 instaling a WRT54GS V7.2 linksys router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url: or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url: and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
Can't access internet, says I am connected but then says no internet connection
I think you should try to reset and reconfigure the Linksys router and see if that works.
If your Linksys router is old then you can also upgrade firmware on the router.
Connect your computer directly to the modem and make sure that you can access Internet directly through the modem.
Connect the modem and computer to the router. Open the setup page of the router and change the settings manually.
Try this website to setup your Linksys router manually.
I can also suggest you a Fiverr Gig where you can pay only $5 and get support for your Linksys router.
Jun 11, 2012 | Linksys Wireless-G Broadband Router
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
I just installed security on my system through my router I used my laptop to enter the pass word. I am trying to connect with my router using from my desktop. All it does is go to search. I...
The security you have installed on your system is restricting access to the router. Whatever security you are using, you need to add the router's ip address i.e. in the exception list.
Oct 11, 2009 | Linksys Wireless-G WRT54G Router
Hello, I just installed a new router, and it all
verify your internet modem it connected to the WAN port on your WRT160N, login to the WRT160N and go to the "status" tab and see what your internet status is. You should see a page similar to this:
Verify your router has an Internet IP address. If it does not, then you haven't finished configuring your router. If it does have an IP address, then turn off your firewall and see if you can get connected that way.
Oct 03, 2009 | Linksys WRT160N Wireless Router
Linksys wrt54g with sony vaio webcam won't work
check the LAN cable from the internet connection going to router.make a sure that wire is OK.if the wire connection is a ok go to your PC/unit then make sure the Lancard/wire less lancard driver is complete or remove the Old lan/wieless lan drivers and install a new or update the drivers.good luck and have a nice day
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Connecting PSP to wifi
Change the primary DNS of your PSP to and secondary dns to
Apr 25, 2009 | Linksys WRH54G Wireless Router
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Password for the Linksys Wireless Router
Power down the linksys and on the back is a reset button push it. The ones i have installed dont need a pass word or key,if it is asking you try the info you used from your internet provider ( e-mail address or access #s)Also try skipping this step and see if it will let you go on to the next part,Lynksys advisor has major issuses with it I dumped it from all the pcs I installed.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have a cable modem, Motorola SB5101, Nd need to connect my linksys wireless router.
If this is a first install of a brand new Linksys router:
Just plug your cable modem to the back of your linksys router's internet port, then plug a computer to Port 1 on your router, type in your internet browser on the computer connected to Port 1, you will access the setup page of your linksys router (leave the user name field blank and type admin as password)
Now you can go to to setup your wireless securely, you do not want to just leave it at its default settings, as anybody could then use your internet access or worst, check what you are doing on your computer.
Let me know if you need more help!
Apr 25, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
129 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
