Question about Admiral AAV7000A
Admiral Washing Machine
I am not sure of the model number, but my washing machine keeps filling and won't stop on either the wash or rinse cycle. It is also not advancing correctly on the cycle dial. Finally, it appears to be leaking out of the bottom of the machine.
Any help would be greatly appreciated. I have a newborn in the house and need to have a washing machine. I can't afford to buy a new one right now.
  • 49 Answers
One of 2 things, either the inlet valve is not shuting off or the pressure switch is not sensing the water level. both of witch would have to be repair by a qualified technician. this repair would be worth doing
Posted on Feb 18, 2008
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
Washer filled up and will not switch to rinse cycle
hi just read your posting.Now does the machine drain the water?Or does it keep washing?Could you confirm the model number for me.Does the machine stop and beep and show an error code?Please reply with additional information on the questions and I am sure I can help you.
Oct 03, 2010 | Fisher Paykel EcoSmart GWL15
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lid switch for admiral washing machine (13 years old)
From description it looks more like you have to replace the lid switch, if you have to push it down, then the contact inside is broken.
You find replacements here, just insert the model number.
Sep 14, 2008 | Washing Machines
Washing machine filling
turn the power off if the water stops it most likley a pressure switch problem or the pressure tube on the side of the outer tank may have pulled off.if you turn the power off and the water doesnt stop then the valve is faulty (cold)if it was on the rinse.hope this helps.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Machine won't stop filling
Sounds like your solinoid valve needs replacing. It cuts the water off when it has reached the right level.
Nov 19, 2006 | Admiral AAV7000A
Admiral AAV7000A Logo
122 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
