Question about Bosch Axxis WTA 3510 Electric Dryer
Sealing Cover? I just bought a second-hand dryer and do not have sealing covers for the two ducts I won't be using to vent. I've searched for the part online and have been unsuccessful. The previous owner said he didn't need/use them. Many thanks! Patti
  • 3 more comments
  • Bleuize Feb 17, 2008
    In the Use and Care Manual for the Electric Vented Dryer, it says in the Installation section (Page 19) , "The duct may be connected to the left, right or back of the WTA 3510 .... remove the sealing cover from the side to be used..." and "The sealing cover should then be placed over the open vent at the back of the dryer ...".
    Patti
  • Bleuize Feb 18, 2008
    Many thanks! That's what the previous owner thought, BUT, when I use the dryer now (without the blankout/sealing covers), exhaust is coming out of the unsealed/unblankedout covers and not drying my clothes.
    The previous owner bought the dryer from his brother, an appliance dealer, so I'll call him to figure this out. I just hope it's resolved before Thursday ... when I really need to do some laundry!
    Thank you,
    Patti
  • Bleuize Feb 25, 2008
    I didn't duct tape the openings - I used wide packing tape and it seems to be fine. I could only seal one opening though because I couldn't squeeze my hand around the other side.
  • Bleuize Feb 26, 2008
    Ouch, got it Master_Tech.
  • Gary Davd
    Gary Davd May 11, 2010
    not sure what you mean by sealing covers?? unless it is a condensing dryer you have to use a vent
Is it safe to duct tape it? hot dry air I assume is not problem for duct tape
Posted on Feb 25, 2008
  • 770 Answers
OK what they are talking about are the blankout covers on the unit so if you vented it out the back the side cover will need to be put on if these are missing it is ok to use the dryer. they are just plastic covers to block off the holes if it really bothers you you can order them from a dealer. but you have to have the dryer vent to somewhere..hopefully outside...
Posted on Feb 17, 2008
  • Gary Davd
    Gary Davd Feb 18, 2008
    You can always duct tape it??
    PlZ rate my service
  • Gary Davd
    Gary Davd Feb 25, 2008
    hence the name duct tape used to tape heating ducts it is ok but silver foil tape is nicer looking
Dryer vent blocked
Dryer vents can block up with lint over time. Remedy is to disconnect dryer from power supply, then disconnect exhaust ducting from the dryer. Sometimes the duct leading to outside air will be plugged. Try using a vacuum cleaner to remove the accumulated lint. Same thing with the dryer. Re-connect the power and give it a test. If there is lot's of air coming out of the dryer, connect the exhaust duct and test again. Check the outside vent to see if there is air coming out. Sometimes there will be a screen under the cover and it will completely block with lint. Lots of people remove the screen.
Hope this helps.
Mar 13, 2015 | Samsung Steam Washer And Dryer Wf457argsgr...
How do you side vent the Kenmore 800 dryer? I cannot rear vent the dryer due to space limitations. I MUST side vent.
You will need to take the dryer apart, pull the drum out. Then at the bottom you will see the main discharge, take it off and insert a 45 degree elbow, you will need to then install hard venting to reach the knock out on the side. Be sure to use metal duct tape when sealing the venting to avaoid fire haz.
Nov 09, 2010 | Kenmore 800 7982 Dryer
How do i repair the heater core on my 1999 ford windstar 3.8 liter engine?
1.Disconnect the cable from the nrgative battery terminal. Drain the cooling system
2.Remove the cowl vent panel, Then disconnect the heater hoses from the heater core inlet and outler tubes at the firewall.
3. on models so equipped, disconnect the engine ground strap attached to one of the heater core tubes.
4.Remove the center dash support trim and the radio cassette box ashtray.
5. Pull back the carpeting and pull the rear airflow duct away from the main floor duct.
6. Remove the two instrument panel support brackets and the heater main floor duct.
7. Remove the screws and the heater core cover, the remove the heater core. (Be careful not to tear the foam sealing material).
8. When reinstalling the heater core in the housing, make sure the original foam sealing the material is intact and in place.
9. The remainder of the installation is the reverse of removal.
10. Fill the cooling system.
Run the engine and check for coolant leaks.
Good Luck!!
Any questions please feel free to post it and I will answer it.
Jul 18, 2010 | 1999 Ford Windstar
I have to change the heater blower moter switch how do I do that
SECTION 412-02: Heating and Ventilation 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 10/6/2003 Blower Motor Removal
All vehicles
  1. Remove the footwell lower trim panel.
  1. Open the glove compartment.
  1. Remove the footwell vent air duct.
    • Pull off the hose.
  1. Close the glove compartment.
Vehicles with electronic automatic temperature control (EATC) built 11/2003 onwards
  1. Disconnect the blower motor control module electrical connector.
All vehicles
  1. Disconnect the blower motor electrical connector.
  1. Remove the blower motor.
Installation
NOTE: Procedure if there is a concern over whistling noises from the heating system.
  1. NOTE: Set the air distribution switch to ""Head area” and the temperature control switch to ""MAX cooling”.
    Remove the ventilation center nozzle and open the glove compartment.
  1. Unclip the passenger side defrost nozzle air duct and position it on the open glove compartment cover.
  1. NOTE: Do not allow any parts of the joining tang to pass behind the instrument panel.
    Remove the two-part plastic joining tang on the heater housing.
    • Cut the joining tang at the top end using side cutters, break it off at the bottom and discard it.
  1. Cut the sealing tape into a 50x50 mm square.
  1. ani_caut.gif WARNING: Sharp edges on the heater housing.
    Feel for the gap in the heater housing, affix the sealing tape over the gap from the inside and press it firmly in place.
    1. NOTE: Apply the sealing tape in the position shown. The sealing tape must not be applied higher than the position shown in the illustration.
      Heater housing (shown in cross section)
    1. Sealing tape
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=g18286&c35=wsm%2cblower%20motor%2csyy%2c412-02%2cremoval%20and%20installation&pid=wsm%2cclimate%20control%20system%2csyy%2c412-00%2cdescription%20and%20operation&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=29&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=491&ct=lan&hp=n&[aqe]
Apr 04, 2010 | 2000 Ford Focus
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
4l60e just rebuilt no second gear
your problem is in the 2-4 servo assy. area. this the round external cover on the right frount side of transmission.remove cover and remove servo assy.Check the teflon sealing rings for nicks or cuts.The 2-4 servo and band are on in second and fourth gears.It is quite easy to nick or cut the sealing rings on installation of 2-4 servo assy and cover
Aug 02, 2009 | Chevrolet Camaro Cars & Trucks
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Dryer won't heat. Motor turns tumbler. Tried
Heres what you'll need to do.
First pull out your lint trap and place your hand down in the lint trap hole not very far just enough to feel a good amount of air blowing on your hand. If you feel no breeze in there you need to clean the ducting, starting at the back of the dryer (where you hook it up at) and ending out side your house (where vents at). Snake it your self or have someone do it but just the same it has to be done.
Secondly you'll need to change you thermal fuse. If after snaking the dryer still doesn't heat. Changing the thermal fuse is easily done. Firstly you must unplug the dryer and then remove the cover off of the back of the dryer. Then you'll see the thermal fuse
e05e4038970ae97c (most of them look like this). Change it and put the dryer cover back on, plug it in and your ready to rock and roll.
Hope this helps
Jason
Apr 02, 2009 | Maytag MDE2600 Electric Dryer
Whirlpool supreme dryer will not get hot
Hope this helps
Jason
Mar 21, 2009 | Whirlpool LER5636P Electric Dryer
Door leaks
This dishwasher has a vent at the bottom left of the door that blows out hot moist air during the drying cycle. Are you sure that you are not getting condensation build up from this vented air that is dripping on your floor?
Dec 29, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Bosch Axxis WTA 3510 Electric Dryer Logo
79 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
