Question about Zanussi WJD1667W Front Load Washer / Dryer
Cant use dryer
Not quite sure how to use dryer should i wait or use straight after wash
    Problem Solver:
  • 5 Answers
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Posted on Dec 20, 2008
Fabric conditioner goes straight through
Fabric softener can build up in a machine and cause problems so my suggestion is to quit using it and switch to dryer sheets instead. An alternative is to use sponges with your liquid softener. Click on this link: http://lifecheating.com/2013/11/16/never-ending-dryer-sheets/
Nov 25, 2014 | Washing Machines
Washer quit working, door is locked, net to get wet clothes out of washer
drain out the water by putting the hose low down also disconnect electricity
Apr 10, 2013 | Splendide 2000S Vented Washer/Dryer
My dryer quits working after a period of time, how
You have a motor going bad . Thermostats only control the heat . Replace the motor and that should take care of the problem .
Apr 30, 2010 | Maytag Dryers
My dog ate my power cord on my bosch 1200 classixx washer, can it be replaced??
Yes, it is a quite straight forward job to replace the cable.
Remove the top cover and follow the cable in, you will then see what is required .
Alternatively, if you do not want to do this, you could join the cable with a 3 pin connector plug
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD63 Front Load...
No manual for Defy Kombomaid - cant get dryer to work
The dial to the left operates the dryer. Select amount of drying time, push same start button as for washing machine and voila! Also you can go directly from wash mode to dry mode without machine pausing. Select your wash cylcle, your drying time and push start.
Apr 14, 2009 | Dryers
LG Tromm DLE Dryer never dries my clothes when the cycle is done
ok there,first the clothes must come out off your washer well spun,or dryer will work extra hard/long.next you dry a load with out ducting to elimanate your house venting[you wont hurt a thing]most off the time thats it![house]if still bad and you know your dryer is cleaned out then its an electrical problem.will go ther after you check the above.God bless.please help with my ratings if i have be helpful,tom
Jan 02, 2009 | LG WM2688HWM TROMM SteamWasher
Mildew smell on clothes
I have the same machines. Try using an old towel and detergent solution( use rubber gloves) and thouroughly clean the door seal. It can be just full of old lint, dirt, etc. in the grooves. Also try some oxyclean in your next load. That will help get rid of the odor also. These washers stay warm quite a long time and clothing will mildew fast in warm weather, but you probably already know that.
Aug 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
I HAVE A KENMOR DRYER MODEL NUMBER GGQ8811LL0 AND I CANT OPEN THE FRON ACCES PANEL I DONT KNOW HOW
Hello Velasco,
You have what is known as a dott dryer and to open the control panel you should take a flat blade screw driver and slide it straight into the groove above the bottom panel. about 2-3 inches from each side. when you find the small clamp you should simply push the screwdriver straight into the clamp. Pull out on the side of the panel and it will open. Please make sure to disconnect all power before you open the unit as there will be wires that you could touch. Good luck and I hope this helped.
Apr 30, 2008 | Dryers
Brand new washer dryer leaking - Triciy WDR1241
Go back to dealer ,make sure it is plumed OK .close bye
Oct 08, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Zanussi WJD1667W Front Load Washer / Dryer Logo
245 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
