Question about Mitsubishi WS-65611 65" Rear Projection Television
Ws-65611 won't power up
Problem started initially with the remote control not working. We just opted to turn it on the old fashion way. That worked for a while then the power button would not work; but Enter or Menu would power up the set. Now nothing works. I have attempted to leave the unit unplugged for an hour. When replugging in the set, I hear a capacitor charging noise initally. I tried the system reset with no response. Still nothing works. Any ideas would be greatly appreciated!
  • desertstone Feb 19, 2008
    Yes, it works through the remote. As we were looking through this forum, we saw a similar problem and tried disconnecting the front panel and the remote worked. Now we are just trying to find somewhere to purchase the caps which is not an easier endeavor. Any online recommendations? Thank you for the response.
Before you get real crazy about buying caps how are the solder connections and the control panel may have bad solder joints and you may find that a can of contact cleaner may help the power button. iv seen it before if you know that the caps are leaking then replace, but still solder main board and here are people i deal with bursma electronics in bay city michigan dont have # right off hand but these people will help but make sure when you unsolder caps you ckeck them out of circuit and make sure you have the polarity right when changing good luck let me know how how every thing works out shad
Posted on Feb 19, 2008
  • 126 Answers
So will the set power up right now
Posted on Feb 18, 2008
  • shad holland Feb 18, 2008
    try universal remote
The problem started initially with the remote control not working. When I turn the TV on at the control panel the volume is all the way up. When I turn it down and let go of the volume button it...
Check the volume up button. It is either just stuck or defective, causing a constant stream of data to be sent to the microprocessor. You remote isn't recognized because the data line is continuously active.
Aug 31, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
MODEL WS-65611 TV DOES NOT RESPOND TO REMOTE. HAVE REPLACED BATTERIES AND RESET THE TV. REMOTE LIGHT WORKS.
Is your remote one of the "universal" ones that allows you control multiple boxes?
If so, be sure you are selecting the correct input (TV, DVD, AUX, SAT...etc).
It's also possible that you will have to reprogram your TV to accept the remote's input. This can happen even if the TV and the Remote were sold together. Check your TV/remote manual for the syncing instructions and associated codes.
Oct 13, 2009 | Mitsubishi WS-65611 65" Rear Projection...
My tv turns on the shuts off on its own
This unit will not indicate any problem without you doing something to initiate the LED diagnostic feature. Go to the front of the set and hit the power button, when that doesn't work hold the MENU and INPUT buttons on the set at the same time for 10 seconds. The power LED should start blinking a two sequence code that will repeat six times. The number of blinks will tell the general area of the problem. As an example a 2 - 2 sequence is a convergence output problem over 95% of the time.
Jun 04, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Tip
I hope that helps.
REPLACEMENT PART FOR FRONT BUTTON CONTROLLER FOR WS 65611
Mine uses 6mm x 6mm x 4mm switches which are available from places like Mouser.com. Good luck.
Mar 10, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Mistsubishi HDTV 1080 Model WS-65611
hey there! good thing you posdt back. i dunno what happend earlier but that wont stop us would it. haha
anyway right,
have you tried changing your remote? it may sound odd but your tv may be fine and the remote is causing your tv to be like that.
you should try changing the remote first ok! cause probably a diode is messing the wat your tv should work.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mitsubishi WS-65611 65" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
