RCA Rear Projection TV P46770CK spark beneath chassis when power applied
My RCA 46 RP model# P46770CK/Chassis # PTK169PAAS tv no longer powers up - when power is applied to the unit a small spark is seen to come from directly under the power adapter plug on the motherboard/chassis. The fuse has been tested and is fine. i have used various power outlets with same results. I am at a loss where to look next
  • 211 Answers
It sounds to me that you may have a cold solder joint ( loose connection on the board ). I suggest you remove the board ( or seek professional assistance ) and solder any loose connections that you may find. That may correct the problem. Good Luck.
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Posted on Feb 18, 2008
Model number p46151wk, can turn tv on with power button but automatically turns back off
A number of possible answers---I need to know two things= on back of set aside from model number is there a chassis number like PTK 195 etc? Is power light green and going off or remains on?
Aug 27, 2012 | RCA P46924 46" Rear Projection Television
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
RCA Projection TV
Located on the power supply right next to where the power cord hooks to the chassis. However most models have 2 or 3 fuses.
Apr 06, 2008 | RCA P46812BL 46" Rear Projection...
Rca model p52721lv
whats the chassis number Rca has to be cross referenced by chassis number
Mar 19, 2008 | RCA P46924 46" Rear Projection Television
TV fried from power surge
What is the chassis number? It should be located on the rear of the set. Have to have the chassis number before I can help
Mar 03, 2008 | RCA P60920BL 60" Rear Projection...
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
RCA P46770CK
Check Cr4503 in the vertical circuit for short or leaking. The convergence circuit is most likely fine. Also check for any leaky electrolytic caps in the 500 block. (example) CR4503 will be printed on the PCB as CR503. The vertical circuit is located in the center of the chassis behind the big aluminum heat sink.
Nov 01, 2007 | RCA P46810LV 46" Rear Projection...
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
