Question about Sewing Machines
Sewing machine stuck on reverse only
Everything moves just fine.
I was making curtains, sewing straight and did the reverse and it stayed on reverse. My husband took it apart and did not find any problems.
  • Anonymous Jan 12, 2009
    ditto, ditto, ditto
The same thing happened to me. I think this machine is just junk!
Posted on Aug 11, 2008
Keep breaking needles when i put down presser foot to sew iwant to sew straight stich to hem a curtain
If the needle is hitting something, make sure you have the machine set for straight stitch and the needle is in the center position. If it is still hitting and breaking, then the machine is out of adjustment and needs to be repaired.
Mar 20, 2017 | Sewing Machines
Why does my Janome JB 1410 only work in reverse? I am not pressing the reverse button
I would check their website for technical support or call their hel hotline . should be listed in your manual
Aug 27, 2016 | Janome Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
When making buttonholes, the machine will not zig zag in reverse when doing the right side of the buttonhole.
1. Remove the top.
2. Clean the inside with carburetor cleaner and lubricate with sewing machine oil.
3. While After this move the stitch length back and forth from a long arm to the reverse mode. Rotate the hand wheel several times to lubricate all moving parts.
4. Place some rags under the pressure foot and watch if the rags will back up.
5. Remove the bottom of the machine.
6. Clean the bottom moving parts and lubricate.
7. Rotate the hand wheel and watch the feed dogs to see if everything is moving.
8. It is possible to notice a screw attached to the stitch length adjuster that will have to be tightened. This may require you to move other parts that are attached and apply pressure while doing this.
Apr 02, 2015 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Dec 30, 2009 | PfaFF Sewing Machines
Singer 7442 stuck/jammed
you may have some lint not seen and use some canned air and try that you may need a new needle it could be bent. or even broken and a piece is still in the little tight crease in the bobbin holder.try all that first and then check your tension did it get moved by the fabric? when you wrer making the curtains?
Feb 28, 2009 | Singer 7442 Mechanical Sewing Machine
Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Nov 13, 2008 | Brother CS-8150 Computerized Sewing...
Jerome harmony 4035
Most likely is that the reverse mechanism is jammed with old oil and lint to form a glue.......especially if the machine has not been used recently or regularly.
If you can remove the base plates from underneath easily, then try to operate the reverse lever, you will see a metal lever trying to move a collar around the shaft......apply a small amount of WD40 or similar to both sides of the join then press the reverse rapidly for a while, move it by hand if necessary back and forth..........with regular use this is rarely an issue, it is most common when the machine is idle for long periods.
If you cannot remove base plates easily, ie if the case is split down the middle in 2 sections, take it to a Janome Dealer who has the repair manual as trying to split the case yourself without the manual is very difficult and you will probably break the retaining clips.
www.bargainbox.com.au
Oct 29, 2008 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
256 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
