Question about HP LaserJet 3330MFP All-In-One Printer
HP LaserJet 3330MFP quit recieving & sending faxes
The fax machine has worked well, until a couple days ago. When a call is coming in, it show incoming call, then shows no fax received. When trying to send a fax, it shows no fax sent. I hear no dial tone, and see no error messages. Tried T.30 Protocol Trace which shows0.00 OFFHOOK, 6.49 CNG and 10.00 ONHOOK. No other information. A new fax machine works well on the dedicated line, so I believe the problem is in the fax machine. Any suggestions?
  • 1 more comment
  • RGCraig Feb 27, 2008
    I had figured out that may be the problem, but not sure enough to order the part. I've even had it out. I just ordered it. I will let you know if that works.
    Thanks!
  • RGCraig Mar 05, 2008
    Thanks for suggesting the source for the L.I.U.; it was much cheaper than HP. I received it today, and replaced the old one. Still, it does not work.
    If I watch the screen when it is receiving a fax, it first shows "Incoming Call", then says "No Fax Detected." I printed a Fax Activity Log, and it shows that each received call shows "No Fax Detected."
    At this point, the only thing I can figure is that either I have the ribbon connector in wrong, or it is bad.
    Any help would be appreciated.
    Thanks,
    It worked fine
  • danielle217 Jan 08, 2009
    Suddenly the bulb takes forever to warm up and I also have a message "no fax detected"?
    Problem Solver:
  • 13 Answers
Your Line Interface Unit (L.I.U.) is bad. The part # is C9138-60001. Google for part availability.
1 Open or remove the left side door.
2 Remove one screw at the left of the formatter board.
3 Disconnect the flat flexible cable from the connector.
4 Rotate the LIU around the hooks to remove.
It's about a 5 min job. Good Luck.
Posted on Feb 27, 2008
  • Brad Clapp Mar 05, 2008
    Are you running your phone line through a surge protector and is the line working? Check the cable, make sure the ribbon cable is installed correctly and completely. Was the part you bought new or was it a "pull"? There really isn't anything else it can be unless the replacement part is bad.
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Incoming faxes do not show time or date
function-7-4-start-9-start-2-start-stop
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
Can't receive faxes
i just wanted to know can you adjust the incoming phone calls to fax machine
Aug 11, 2008 | Lexmark X8350 All-In-One InkJet Printer
Vertical lines on copies received
Run a copy of something through your machine. IF the lines show up on your copy, and also lines on your incoming faxes, then your drum cartridge is bad.
Replace the drum cartridge with a new one and you should be back in business.
If you have any other questions, please post again.
I hope I have helped you with your question.
Please remember to post a rating if I have helped you.
Have a good day.
Mac =)
Jun 04, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Can't receive outgoing faxes, but CAN receive in-house faxes
MAKE SURE YOUR PHONE LINE IS PLUGED INTO THE JACK ON THE FAX THAT IS MARKED LINE ALSO CHECK THAT THE MODE KEY IS SET TO FAX
Oct 23, 2007 | Brother IntelliFAX 4100 Laser Fax
HP LaserJet 3330MFP All-In-One Printer Logo
268 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
