Question about Goodman CKL49AR49 Air Conditioner
Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
Have been running the heat with no problems until today . It ran all night and into the mid day. I then began to smell a burning smell. Like when you turn the unit on for the first time in the winter. I did not find and smoke any where , just the smell.
I took the front panels off and looked for anything that might look burnt. Didn' t find any thing. Blew the dust off and turned the unit back on. Still a strong burnt smell. I set the thermostat to 90 and it ran a few minutes and shut off. The termastat on the wall read 75 degrees when it cut off. It
stayed off for a few minutes and came back on for a few minutes. I have truned all the brakers to the unit off untill I can find some help. Is there anything elese I should do untill I can get some help?
  • 4 more comments
  • varn4620 Feb 17, 2008
    It is Electric. Air and heat in the same unit. Let me know if this is no help? Thanks
  • varn4620 Feb 19, 2008
    It is not a heat pump.
    The unit runs but cuts on and off, and has buring smells
    I am now having the compastor replaced on the blower it is not reading right. Hoping that is the only problem
    Thanks for the help.
    It was the capacitor (thanks for the help with the spelling)
    We have heat and it only cost $96.30.
  • varn4620 Feb 20, 2008
    I't a $15.00 part. And the service call was $75.00.
    That's one of the down fall to living in the sticks. No one wants to come out this far. That is why I look for a way to fix things my self first.
  • Gary Davd
    Gary Davd May 11, 2010
    Ok does the unit outside run at all in the winter time (ie.,.a Heat Pump) or is it stright A/C. if it is an Electric furnace then you may have cooked an element. or burned out a Squencer. Let me know also check the wiring and incomming voltages off the breaker
  • Gary Davd
    is this unit a heat pump or gas furnace you have posted under A/C
    Sergeant:
  • 288 Answers
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Posted on Feb 19, 2008
  • 1 more comment
  • Rob Luna
    Rob Luna Feb 19, 2008
    I knew it wasn't a heap pump by the model #. If the heat comes on without the fan. It will eventually heat up high enough to engage the high temperature safety. As for your repair,do you mean the CAPACITOR for the motor? That's a good start, it starts the motor and its much cheaper. If that doesn't do the trick then it motor time. Usually when the capacitor goes out, it bulges out on the sides and leaks. Make sure the person who replaces it uses the right size= volts and microfarad.
  • Rob Luna
    ONLY $96.30!!! its a 8 to 10 dollar part. What's the labor rate there?
  • Rob Luna
    Rob Luna Feb 21, 2008
    Thats about standard suff, I guess. At least I was on the right track.
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
Its 28 degrees out side and my goodman 3.5 ton heat pump package unit is blowing cold air out of all my regesters
Sounds like the heat pump is not running. Check outside to see if the fan is spinning.
Try moving the thermostat to emergency heat and see if that gives you any heat. If it does, then you have heat until you can get a service technician to locate the problem with the heat pump. It could be a wide range if issues from bad thermostat to bad wiring to bad capacitor.
Jan 07, 2010 | Goodman Heating & Cooling
Whirlpool gas dryer, no heat and no flame
check you thermal fuse with an ohm meter if selected only air and close the door and no air comes from the rear where the vent hooks up clear the vent blower housing then check the thermal fuses on the units exaust assy inside the unit
Aug 19, 2009 | Dryers
I have a Goodman Heat Pump System Model ARUF032-00A-18,
That sounds to me like you lost your low voltage power. Bad transformer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Goodman CKL30AR30 Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Defrost Cycle Problems
You need to replace the defrost board and sensor
Nov 21, 2008 | Weather King 10AJA6001AH Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Goodman CKL49AR49 Air Conditioner Logo
1,207 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
