Question about iRiver H10 MP3 Player
4.6GB Iriver H10 Merory says 2.9GB remaining but there is nothing on the player.
I have a H10 4.6 GB. I have deleted all music and other media, pictures, recordings etc but it says I only have 2.9GB remaining. How do I get back to 4.6GB of free space ? pleeaaassee
Considered formatting disk?
For you what this would mean is just a complete refresh of the device (you will lose everything).
You will need to read everything carefully.
Check this out
http://www.misticriver.net/boards/showthread.php?t=14853
I converted my H10 to the "UMS" mode mentioned in the site a long time back (so I could directly transfer files as a USB mass storage device) and had the issue mentioned in that post. Works great. Converting to UMS mode is done here http://www.misticriver.net/wiki/index.php/H10_Firmware_Conversion:_MTP/UMS
You will also need the iRiver Plus software that you can download for free here http://www.iriver.com.au/iriver/index.cfm?pageID=10001&
Posted on Feb 19, 2008
My iRiver H-10 when I sync music from my library (pc)doesn't work because:sync your device to your pc appears ! What's this ?
Try to reconnect to the computer after updating the software/ firmware in the H10.
Here is for the Iriver H10 software:
http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 23, 2009 | iRiver H10 MP3 Player
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Apr 13, 2009 | iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
H10 6gb
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Aug 26, 2008 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
Delete music H10 iriver
Sorry, but the built-in firmware only allows you to do that by plugging it into your computer as a removable device. Pull the battery of the player (or press the reset button), plug it into your computer, and press and hold the OK button as you turn it on. This will cause the computer to recognize it as an external drive, and you can therefore delete music from it by accessing it through My Computer.
Dec 21, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
134 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
