Question about HP LaserJet 2840 All-In-One Printer
Printing on right side only
I installed remanufactured yellow, magenta and cyan cartridges at the same time. Although I was printing black text just fine before the change, afterwards all four colors are printing on the right side only...fading from normal print on the extreme right to faint print in the middle and to nothing at all left of center. I have seen this problem described elsewhere and a discussion of a possible carousel misalignment. I am doubtful this is my problem, however, because the right color cartridge is showing when I open the panel after I press the cartridge rotation button. Can this nevertheless be a carousel alignment problem even anyway? And if it isn't a carousel alignment problem, what else could it possibly be? I have a service manual and the mechanical know-how to take it apart, if necessary, but that will be a last resort.....
  • 7 more comments
  • LouisianaJan Mar 23, 2008
    My printer is only printing on the right side of the page with the old and now the replacement of all colors. I read somewhere that the axel needs to be realigned. Can anyone offer instructions on how to do so? Thanks so much
  • robertinski Mar 24, 2008
    Thanks, smuteanua, your diagnosis was right on. The carousel
    gears were misaligned on the right side by a mere single gear tooth! I found a
    copy of a couple of pages form a field service manual online which described
    the repair. I was able to accomplish the repair without removing any of the
    printer covers thankfully. Here's what I did.
    First, I used a large straightened paper clip and inserted it to release the
    carousel brake/clutch. Open the toner cartridge cover and look for a small
    square opening/hole on the top right side. You will see a small white plastic
    part inside the opening, and it also has an opening it it – that’s where the
    thin screwdriver or long paper clip should be inserted to release the
    brake/clutch. Now the carousel should turn freely. This will enable you to
    align the gears.
    You are looking for a large black gear on opposite ends of
    the carousel (which is actually more like a ferris wheel). The large black
    gears are marked with letter codes each color of the four toner cartridges: K
    for black, M for magenta, Y for yellow, and C for cyan. A small ½ to ¾ inch
    diameter white gear sits atop each of the black gears. Two small pins protrude
    from the small white gears. Turn the gears until you spot those pins. Those
    pins must align with a mark on the large black gear. The “mark” on the large
    gear is actually more of a slot, notch or groove, and there are more than just
    one of these markings on the large gears so you have to find the right one. The
    single mark on the larger gear is adjacent to the slot for the black cartridge,
    marked with a “K.” See the illustration below.
    The field guide describes the repair like this: “To re-index
    the carousel, grasp the black carousel gear and pull the gear inward while
    pushing outward on the white gear. When the gears separate enough to skip
    teeth, rotate the white gear around in the proper direction to correctly index
    the carousel.” While the field guide contemplates removal of printer covers and
    full exposure of the gear system, I was able to accomplish the repair without
    going through all of that. I gently pulled the larger gear inward enough so
    that the gear teeth disengaged, allowing me to realign them by one tooth. If
    you scour the internet, you can find a pdf of HP’s service manual but it was
    not of much use to me for this particular repair. The couple of pages I found
    of a repair field guide were what described and illustrated the repair for me
    (although it was not of the 2840 but close enough). I will share either or both
    the manual and field guide with anyone who requests them and provides me with
    an email address to which to send them. Good luck to you!
  • JDuChemin Sep 29, 2008
    So I have taken out the toner and drum several times and recorrected the allignment of the carousel. Everytime I put them all back in the gear skips over one notch and it goes back to printing on the right side only. Any one know why this might be happening? Am I causing this or is something wrong with the printer gears? This is freaking annoying........................
  • fredavide Nov 13, 2008
    Everytime I fix the alignment. It skips a tooth and I have the same problem once again. This solution is not working for me.
  • JDuChemin Jan 28, 2009
    I have 2 HP 2840's with the exact same problem. On both I have tried to re-align the gears like described abouve but neither of them will stay that way. I am going to have to try and clean them like described above...I will keep yall posted.
  • JDuChemin Jan 30, 2009
    So Junkerette did cleaning off the gears work for you as a permanant fix? I am going to try to do that with both my printers tonight to see what happens!?!?! Goodness I hope it works........
  • felicia897 Feb 25, 2009
    only printing on the left side and is actually getting worse when printing test pages. Looks like it will eventually stop printing anything if I keep testing it.
    It sounds like I need to align my cariusel....
    Anyone have directions to do this?????
  • Anonymous Mar 17, 2009
    sounds just like whats going on here - remanufactured yellow cartridge & out of whack carousel = woud ypu mind emailing the pages you found hel[ful to danlight1@msn.com [;ease? Thank you! Dan
  • i22yb May 11, 2010
    In response to ChadFromOC, your theory about remanufactured cartridges and leaked toner causing this problem may be applicable in some cases; however, my problem occurred immediately after a paper jam.
  • 26 Answers
Ok, for those who are having troubles releasing the clutch.
when i fixed my printer, i didnt even know there was such a release.
i fixed it in an other way (not for the faint hearted)
open the printer, remove all cartridges and photoconducter unit.
when misalligned, you will notice the guides where the toner cartiridges slide into place, left and right, are shifted.
the part of the printer body guides misalign with the carousel guides.
basically, what you need is a big screwdriver.
push the big screwdriver on the right side between the carousel and the body.
the black plastic ferriswheel will bend inwards, enough to go free from the little white driving gear wheel.
now move the right ferris wheel 1 notch into position.
ready. reinstall toners etc.
be carefull not to break it.
it does work, done it on 3 machines now.
the only reason why this happens which i could find,
is that there was a toner cartridge that is stuck.
feel if you can rotate the white cartridge gear by hand.
if not, that is your problem.
possible lesson:
do not over fill your cartridge.
it is perfectly possible to refill, done that many times with these machines, but dont overfill.
ot maybe it is moist in the toner or something.
these cartridges dont have eternal life
good luck, dj
Posted on Jun 01, 2009
  • haris May 16, 2012
    can u show me the picture or video please??
THANK YOU, THANK YOU, THANK YOU!!! This worked amazingly well and only took about 30 min.
Posted on Jul 16, 2008
UNBELIEVABLE.....THIS WORKED PERFECTLY!!
Posted on Apr 28, 2008
  • 43 Answers
Hey there. I am a Custormer Support Engineer.
In about 99% of these problems, the solution is to reposition the carousel to the right position. If you whant to verify that this is really you problem, stick a thin screwdriver into the carousel clutch - top/right under the cartridge cover to manualy rotate the carousel. When a developing roller is in the closest position to the Drum look from the top straight down and you can see that the distance betwen left and right is different.
Posted on Mar 18, 2008
  • lalloon Jun 01, 2011
    Thank you robertinski for a pix that you posted, Printer works fine now, It was the magneta toner that was causing it to go out of alignment.
Great post! I instead used a metal rod and stuck the tip behind the carousel near the white gear and leveraged out the carousel just enough to move it back into place an wa lah!
Posted on Apr 20, 2010
Hi!
I have repeted the step about 10-20 times but i can't get the white gear to rotate only one notch.
I have taken the screwdriver in the hole (top, right) and released the white thing but no different.
I have spent days on this problem and i want it solved now because i don't want to waste my days on printer problem ..
What have i done wrong?
I keep getting print on only laft page.
emil if neseccry: maxx_413@hotmail.com
Posted on Jul 28, 2009
Hi!
I have repeted the steps my the whole day but i keep getting print on only right side, and i can't get my white wheel to rotate ..
I can only get my white wheel to spin one notch not rotate :(
What have i done wrong?, im tierd of this have spent days on this problem!!, i went it solved now.
I had the same problem. Fantastic, easy to do solution! I would, however, recommend that after you vacuum the toner, that you use a soft toothbrush to remove remaining toner from the black gears, on each side of the carousel, and follow-up with a q-tip dipped in alcohol for stubborn toner residue. I wanted to get it done right the 1st time so I could get back to work. Also, to re-index the the carousel, it was easier to grab the black carousel "at the top - using a tilting motion", pulling inwards. I tried to pull straight out & struggled with it. Thanks for the great advice!
Posted on Jan 28, 2009
I had trouble releasing the break/clutch. I was able to find the small white plastic part inside the square opening, but didn't really see the second opening on the white plastic part. Inserting a paper clip into this second opening is what releases the break/clutch.
So looking down on the printer, find the white plastic piece as described above. The second opening on the white plastic piece looks like a tiny square black hole at the bottom of it. Again, that is where the paper clip is inserted.
I was in the correct place the first few times I tried, but I used a small screw driver that was not small enough, so it wasn't fitting into the tiny square black hole. I found that as instructed in the original reply, a paper clip worked perfect. I guess I thought it too small and flexible so I went with the screw driver... that was a mistake.
Posted on Dec 10, 2008
Hello:
You are a genius,
I played with this for three days.
After I read your instructions, it only took 3 minutes
Thanks.
Jfernandez
Posted on Aug 13, 2008
  • DoctorXX Feb 10, 2011
    I dont see how you people are able to get to the white gear. I can hardly see it let alone moving it in the right position. Also, when the gears are aligned, is the area when the cartridge goes in supposed to be aligned so you can just slide one in?
  • 3 Answers
Thank you robertinski. You description was excellent. I had a copy of the service manual and was about spend a few hours tearing into the printer, taking off panels and parts to get to the gears, and you made it extremely simple to get to the gears. And thanks to smunteanu, you were also correct in double-checking the existence of the problem using the spacing of the roller. A few things I'd like to add:
  • After releasing the carousel brake/clutch, you need to remove the toner cartridges so you can see the notch on the carousel. Plus it is a lot easier to work with. I also removed the drum (right in front of the unit). That gives you a big cavity to be able to stick in hands, flashlight, and even your head.
  • First look for the pins on the white gear and notch on the carousel of the LEFT side. I found the left side much easier to see. Then once you know what you're looking for, find the one on the right. I found the two pins on the right white gear harder to see. I marked the two pins with a sharpie marker.
  • Like many have reported, mine was off by just one gear notch (right gear for left side of the page printing blank).
  • After you pull gears apart as described, and rotate the white gear in line with the notch, you might find that the gear do not want to go back together. This time, push down gently on the carousel (black gear), so it will allow the gears to be realigned vertically and pop back in.
  • I suggest if you have toner spill all inside your printer, you also take the time to use your vacuum attachment to get in there and gently remove the excess toner while all of the cartridges are out.
  • After putting all cartridges back in, and you are ready to pull your screwdriver (or paperclip in my case), you need to first spin the carousel back into position. If you do not get the carousel aligned, the printer will probably not align it properly when you turn it back on and you will get an error 54.2 (carousel rotation error) when you try to print a page. After you reengage the clutch, move the carousel to make sure it is locked in place. I found mine spun off alignment and locked in the wrong position, I tried the paperclip release and rotate a few times 9trying different cartridges, until it stayed locked (black cartridge in my case).
I have a theory on why this has happens (specifically). Like my own case, I have seen many incidents of people referring to remanufactured cartridge use and later getting this error. So there is reference to this being the case, but I think it is the specific cause in that: The leaked toner ends up on the gears, and eventually thicken enough to fill up a gear tooth enough to allow a skip.
Posted on Jul 04, 2008
Hello, i have this hp laserjet 2840 all in one printer it's working fine but when i give 10 to 12 print it will show tray1 is empty what i do for this problem it u have a solution please give me reply as soon as possible ok bye.
Posted on Apr 05, 2008
2 Suggested Answers
  • 47 Answers
SOURCE: Printing on right side only
It is the carousel that is dislocated. Check the alignment if it's brooken
Posted on Nov 03, 2008
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Magenta and yellow wont print. new cartridges,black and cyan ok cleaned heads
All new cartridges loaded but no black printing. I changed the black cartridge with a second new one but still no black text printing !
Is this Epson 5800 printer a wtite off at this stage ?
John
Dec 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
Nov 01, 2008 | HP LaserJet 2840 All-In-One Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
HP LaserJet 2840 All-In-One Printer Logo
13,993 people viewed this question
Ben Johnson
