Question about Baby Lock Eclipse Serger
Threading elna lock pro 4 DE green knob
Can''t seem to thread this serger the green knob is where the problem is
have done this tseveral time
  • Anonymous Aug 25, 2008
    After threading, the threads dont lock. I thread it according to the diagram in the machine.Sara
  • sylviaivie Jul 18, 2013
    Make sure you are threading it correctly. Typically it's from right to left.... or lower looper, upper looper, right needle, left needle. Barring that look carefully at the loopers for burs. If you find any use some fine sand paper and carefully file them away.
    New Friend:
My lower looper thread keep breaking, what is the problem.
Posted on Jul 17, 2013
SOURCE: my white speedylock serger 1634 thread keeps getting in knots
i have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Posted on Feb 25, 2009
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
SOURCE: threading brother 1034D
on u tube the show you step by step how to thread the Brother 1034d.
Posted on Apr 06, 2009
Zenqi
  • 208 Answers
SOURCE: I need an Elna Pro 5 DC serger machine Owner's Manual
The original manual is out of print and all that is available now is photocopies and they cost about $15. Let me know if you still need it and your zip code so that I would know how much postage would be.
Posted on Jun 29, 2009
  • 136 Answers
SOURCE: Janome Mylock 534D serger thread 4 (green guides) breaking
what issue?
Posted on Jul 07, 2009
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Oct 06, 2017 | Elna Sewing Machines
What size needles do the Elna Pro 4 DE take, thanks
http://www.sewingpartsonline.com/elna-pro4de-serger-overlock-parts.aspx
https://www.janomesewingcentre.com.au/shop/instruction-manuals/instruction-manual-elna-lock-pro-4dc-4de/
May 17, 2017 | Elna Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
I have an Elna Pro 4 DE overlocker and the thread keep breaking - I have re threaded a number of times now but the thread keeps breaking - it was working fine earlier today - what could be the proble
Try different thread (black thread seems to be more problematic because of the heavy dye). Perhaps, change the needles.
When you re-thread, do you completely remove all the thread and start from the beginning--there could be a snag somewhere or the thread is looped around something, ie the thread tree? ALWAYS RAISE the presser foot when threading. Give each thread an extra little tug when going through the tension disk--it will sometimes make a little snap sound when it seats. Also, make sure you are threading each in the order specified. Threading out of order will generally guarantee a problem.
There is a slight chance something (thread bits, lint) could be stuck in the tension disk.
If it continues, you may want to take it for service as it could be the timing is off.
Dec 12, 2016 | Elna Sewing Machines
I have an elna 664. I have threaded it and cannot get it to sew at all.I need to set it for over locking
When a serger fails to sew, it is most likely because it has not been threaded correctly. Another possibility is that it is out of time.
Sep 21, 2016 | Elna Sewing Machines
When was the Elna Pro 4DE manufactured?
I'm thinking early 90's maybe but can't find a specific release date for this model online.
I do know that the first Elna Locks were released in UK in April 1987 and first models were L-1 (3 thread), L-4 (4 thread), L-5 (combo chain and 3 thread) because I was trained to demo these models.
Differential feed was a feature that soon followed in the home lock market across all brands.
Maybe try Yahoo group Sergers and ask there, there could be some members who have this model.
Mar 10, 2011 | Elna Sewing Machines
I have a Baby Lock BL4-736D serger. I need the
orange-(5-7)
yellow-(4-6)
green-(2-4)
blue-(2-4)
medium weight, 4 thread
Dec 06, 2009 | Baby Lock BL1556
Elna Pro 5DC Serger
Sound to me you should get it serviced. Your timing is off. It also could be your needle make sure you use serger needles
Aug 08, 2009 | Sewing Machines
Sewing Machines Logo
1,179 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
