Question about Vacuums
Not sucking We have an Oreck XL and today it is blowing out dust instead of sucking it up. I just replaced the belt and about 6 months ago, we took it to our Oreck dealer and had it rehauled. I opened it up to check all and it all looked fine. Then I tuned on the machine while unzipped and noticed that the bad does not inflate as it used to. What can I do? Thanks, Connie conpappa@gmail.com
  • conpappa Feb 17, 2008
    OMG!!!!! You are da bomb (as my kids would say...) Thank You so much! It worked, like magic! Tons of pine needles and dog hairs!
    But wait... now I have to actually.... clean house?
    Thanks a lot buddy! ;~D
    No but seriously.....
    Thanks for the help.
    Loving the Net,
    Connie
  • Anonymous Apr 19, 2008
    I have A simler problem but I cleaned out the tube and it still wont **** ,and the bag also dose not inflate please help.
    President:
  • 1,673 Answers
You probable have a clog in the handle tube, or at the bottom, either by the brush or in the neck where the handle goes into. Unscrew that big black nut and pull the handle off of the bootom asm, then you can check it out and see where the clog is. Pull the bottom plate off to see if it is there where the dirt goes in.
Posted on Feb 17, 2008
I cannot keep the bag attached to the handle inside the cover on my Oreck XL Vaccuum. When it comes off dust blows out into the cover instead of the bag which makes it very hard to unzip the cover.
there should be a spring ring that slides up over the bag on the handle if thats missing try and use a couple of heavy duty rubber bands. however i do suggest you order the correct part.
Feb 13, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck roller brush problem
The belt is just stretched. Replace it with one from a vacuum store not a discount store they ARE different. It can happen easily. That's the only thing it could be.
Good Luck!
The Vac Dr.
The Belt:
http://www.vacuummedic.com/product.php?id=257
More info on belts:
http://www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Oct 16, 2012 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
ORECK VACCUM
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747767
Generic problem for all Vacuums
ORECK VACCUM
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
376 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
