Question about Microsoft Excel for PC
Displaying error messages
When a sheet has locked cells, attempting an entry brings up the error message. Is there a way to stop this happening and maybe create a beep instead ?
Geoff Guy
  • 104 Answers
Hi, You should look in the options for locking the cells, there are various options there.
Regards SeaJade
Posted on Mar 07, 2008
I want to know the unlock code of pyramidbloxx i already received the unlock code unfortunately i erase the said text please help i want that game
Assume that prior to functionality the device either phone or computer requested pass codes. Acquiring pass codes in such a situation display message space from where typewritten codes are keyed. A situation where the device requests pass codes least displaying type entry area to type key passes. Attempting to operate the device would produce results either requesting pass codes also display the space area at which passwords at typewritten.
Feb 25, 2011 | Samsung GTC3300 Cell Phone
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
LG env2 will not save text messages
This happened to me. My problem was that i had a memory card, and i accidently put the save options for my pictures to my phone memory instead of to card memory. So it messed up my phone.
May 30, 2009 | Verizon Communications enV2 Cellular Phone
Can't access anything on Nokia 6300. It locked up and gives message of: (Message storage memory not ready) No Nokia place around to take it to. Please help!
The phone's memory is full, which causes the error message and lock ups. This error prevents you from freeing up memory by deleting messages.
Try the following (taken from the Nokia support forum):
1. Delete unused names/numbers from the address book to free up memory. (Perhaps write down the ones you want to keep for later re-entry)
2. Once a critical threshold is reached the msg inbox indicator will blink on
3. Enter inbox and DELETE as many messages as you can before phone freezes up again
4. If phone freezes or you get the error message again, restart and keep deleting from the phone book until it allows you hassle-free msg inbox access as per normal (but don't forget to continue deleting thos messages).
May 05, 2009 | Nokia 6300 Cellular Phone
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Bose Wave AWRCC2 error message
Which error, you did'nt put it in the post.
Mar 31, 2008 | Bose Wave Radio
Txt messages
Error message 38 means there was some type of problem with the number to which you were texting. When sending a text message, make sure you are sending the message to a ten-digit mobile number (assuming you are in the US). If you're sending a text message to an entry you've saved to your address book, make sure that you stored the number with area code in your address book.
If all of that checks out, or if you've had no problems texting to this exact number before, you will want to place a call to customer service with your wireless service provider. They can look at message logs within their network to see what happened and why the attempt failed.
good luck
Mar 26, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
