Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Model GSS22JERFWW
Ice maker will not dispense cubes unless the compressor motor is running
  • 3 more comments
  • Jim Mack Feb 17, 2008
    Out of the front. If the refrigerator motor is running the ice dispenser works well. If the motor is not running you have to hold the paddle switch in for 1 or 2 minutes before it will finally dispense cubes. The water works fine.
  • Jim Mack Feb 18, 2008
    As far as I can tell it is the main compressor motor.
  • Anonymous Dec 22, 2008
    ica maker works fine but will not dispence ,could this have somthing to do with the filter and if so where is it located
  • Gary Davd
    Gary Davd May 11, 2010
    plz tell me what you mean by refrigerator motor?? there are several motors on the unit..where is it located?
  • Gary Davd
    are you talking about out the front of the unit with the door closed?? or do you mean the IM dumping ice into the hopper??
Front of the unit with the door closed, what ever makes the ice come out the dispenser.
Posted on Apr 03, 2008
Ge refrigerator sise by side tfx274 ice maker only gives crushed ice and no cubes
you have bad solenoid, it is a small part next to the motor behind the ice bucket. It lifts up the arm to let the cubed ice out of the dispenser bucket.
May 18, 2012 | GE Refrigerators
I have a GE model GSS201EPJWW side by side fridge. The ice maker makes ice but we can not get the dispenser to operate. At times the water will work but not cubed or crushed ice. What can be done to get...
Dispenser works with a motor which might be jammed. When you see the ice storage bin, there is a steel coil which rotates with the motor and ice falls down from the dispenser. See if the coil rotates at all and if so then the motor must be defective.
May 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSS22JERFWW won't dispense ice
hi
this is the heating element problem ie thermostat ,,u should replace it..
thank u please rate it//
Jul 04, 2009 | Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice Maker
PLEASE CLARIFY THE TERMS "MOTOR", "ICE MAKER SWITCH" AND "ICE TO COME OUT"
FAN MOTOR? COMPRESSOR? AUGER MOTOR?
ICE MAKER ON/OFF SWITCH? DISPENSE SWITCH? DOOR LIGHT SWITCH?
ICE TO COME OUT OF THE ICE MAKER? ICE TO COME OUT OF THE DISPENSER? ICE TO COME OUT OF BIN?
Feb 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
399 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
BOYNISMO
