Question about Car Audio & Video
No light on display
I have a awia cdc-x207 car stereo went to start my car the other day and I now have no light on my display Please help
  • Anonymous Mar 15, 2014
    Can I hook up the awia cdc z107yu without the wiring harness
My display is locked and remote and t.v buttons not working,please give me solution
Posted on Apr 12, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
The power wire may have come loose in the connection, or the fuse has blown for some reason. Check your connections and fuse.
Posted on Feb 18, 2008
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Ford radio 6006 CDC, fitted in Fiesta ST, fault discharge battery
Was wondering if anyone can help got a Cdc error on the stereo 6006? Also wondered how to load the cds into the stereo?
Apr 24, 2010 | Car Audio & Video
Cannot get radio to stay tuned to a station
Make sure the memory wire is hooked up.
May 18, 2009 | Aiwa CDC-X116
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Aiwa CDC-X207
hi yellow go in left bottom corner
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
