Bought a house with GE Monogram double ovens, convention and regular modes, proof mode, but seller did not leave appliance manual. What is the proper way to use "proof" mode?
SOURCE: GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
SOURCE: ge extra large self cleaning oven xl44 mode jgbp28ded1wh
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
SOURCE: F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct". This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash. The grease is now a hard rubbery coating on the surface of the rack. To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good. Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth. Turn on to 450deg for 30 min. Much safer, less costly. Please acknowledge this posted solution if helpful. Have more info if needed- Thanks -Ed
