Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 56 inch projection TV
I recently had a flood in my basement my RCA projection TV had about 6 inches of water around it. It hasnt powered up since. Is there a reset button located anywhere on this set or maybe a fuse blew out?
    Genius:
  • 1,030 Answers
Six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Posted on Feb 18, 2008
What kind of heat issue would my 56 inch projection tv have if after a couple hours shut off and on then then turns off . fuse, power supply . not sure
Sounds like it's possibly your convergence IC's overheating. On some projection tv's, after time, the solder joints on the IC's weaken from the heat and cause them to turn off the tv for it's own protection.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
I have a 56 inch rca rear projection tv and after two hours starts turning of and on for about half hour and then turns off. when we turn it back on it shuts off and comes on fast and then shuts off....
Those type of tv sets get unusually hot at times. Could be a heat issue. Power flow at night is the best. If it's still turning off then, it must be a dust or heat issue.
Have a yellow and blue hazw from left to righton the people and lettering rca 56 inch tv
Hi: this is dur to convergence board failure, there a three micro fuses on the deflection board power suppply that need checking, also while checking these fuses check the solder connections around your flyback transformer as this is the most common reason these fuses fail. If all fuses are good then a replacement of the convergence Board is necessary at this point.
Aug 18, 2010 | RCA P46810LV 46" Rear Projection...
Tv turns off and comes on
have u been using the buttons on the front?
if so it could be the button is stuck on the tv..
or possible a short in ur remote..
Jan 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Flood
You have more than one board that got water on it. Most likely a lost cause. Check with home owners insurance for repair or replacment value.
Feb 18, 2007 | JVC AV-56WP30 56" Rear Projection...
56 projection t.v. color problems
If you mean they are separated like a 3-D effect, then you have the typical bad convergence IC problem. There are two IC's mounted on a large metal heatsink, they will have STK392-###, the ### being differant models of TV sets. these are soldered into place and are no usually replaced by the user, unless you have solid state repair experience, knowe how to solder, have a schematic on the set, and know the High voltage safty factors of projection TV serviceing. If you have no experience, please play it safe, and get someone who is trained to service TV sets. Good Luck Please do not forget to rate this thread.
Dec 08, 2006 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
277 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
