Question about Baby Gear
CLUTCH SLAVE CYLINDER
MY SONS 95 TRANS AM CLUTCH SLAVE CYLINDER WENT OUT AND I CANNOT FIND ANY GOOD INFO ABOUT REPLACING IT
  • 2,039 Answers
What can i do for you sir let me know
PIERRE
Posted on Feb 17, 2008
Adjust the clutch linkage on a pontiac 2002 trans am 6 speed
How to adjust clutch??? 95 bird. - Fourth Generation Pontiac ...
www.firebirdnation.com/forums/.../65178-how-to-adjust-clutch-95-bird/
Dec 5, 2008 - posted in Fourth Generation Pontiac Firebird (1993 - 2002): I have ...Year: 2000; Make: Pontiac; Model: TRANS AM; Engine: 5.7L LS1; Transmission: MANUAL 6 SPEED T-56 ... Have you looked at your clutch master cylinder. Throttle is sticking after acceleration - Fourth Generation ...
Oct 7, 2011
1 Problem / Few questions - Fourth Generation Pontiac Firebird ...
Mar 26, 2010
Firebird Technical Service Bulletins - Fourth Generation Pontiac ...
Jul 5, 2006
TECH ARTICLE MASTER INDEX Look Here - Firebird Nation
Aug 18, 2004
More results from www.firebirdnation.com
How to Install Clutch 98-02 LS1 F-Body Part 1 of 2 - YouTube
? 12:31
www.youtube.com/watch?v=4BCHu2BwBMs
Apr 12, 2013 - Uploaded by MapleBoarder78
Part one of installing a new clutch on my 2000 Trans Am. Part 2 will include installation ... How to Master Cylinder Install and Drill Mod (LS1 F-Body) - Duration: ... 6:28. Removal and Servicing ofClutch Master Cylinder to Slave Cylinder ... LS1 98-02 Chevy Camaro Z28 SS Pontiac Firebird Trans Am F-Body ...
Nov 02, 2015 | Pontiac Cars & Trucks
1990Toyota Celica standard trans stuck on fourth gear
Hi Randy,check your clutch master cylinder,if real low or empty.your clutch slave cylinder or master cylinder is bad,the slave cylinder is located on the side of the transmission with a hydraulic line connected to it,here's a repair guide on replacing it. SAVE 20 ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE Here's a link on replacing the clutch master cylinder, SAVE 20 ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
Jul 17, 2015 | Cars & Trucks
Do you have to drop trans to install slave cylinder on 95 ford ranger
I know the regular sized Ford pickups had the slave cylinder inside the bellhousing, requiring transmission removal for replacement (not very smart, Ford!) So I suppose your Ranger, too, if you don't see the cylinder on the outside.; Most people who go through this replace the whole clutch and the slave cylinder at the same time, to avoid having to do it over again.
Nov 05, 2012 | Cars & Trucks
1990 camry shifting cable went out
your clutch has went out or the slave cylinder to clutch or clutch master cylinder ck master for fluid if low fill and work clutch peddle to pump up slave cylinder if master is full ck at trans to see if slave cylinder is moving if moving clutch in most likely bad and needs replaced.
Jul 15, 2012 | 1990 Toyota Camry
Was driving home and pushed clutch in and it went to the floor, did my linkage break or just come off?
if the fluid is low, the hydraulic system is bad. plan on replacing the master and slave cylinder. If the fluid is OK, then watch the linkage when pressing the clutch pedal. I ASSUME it has linkage but I dont know what year or model you have? the trans will have to come out to service the clutch slave and in that case you may need to replace the clutch assembly. Plan on a new clutch, master and slave cylinder.
Sep 06, 2011 | Chevrolet Camaro Cars & Trucks
How do remove slave cylinder
This type of slave cylinder has to come out with the transmission. Sorry, you will have to pull the trans as if you are replacing the clutch. As you might as well replace the clutch assy. if you go in after the slave cyl. due to a leak. Hope this helps.
Feb 20, 2011 | 2001 Chevrolet S-10
I went to start my car today and pushed the clutch in and it went straight to the floor on my 06 chevy cobalt ls. Can you help?
Check the fluid for the clutch. It has a small master cylinder next to the brake master cylinder. It should use brake fluid. If it is low, top it off. If it goes low again, you'll need to investigate where it's leaking from. You could have a leaking master or slave cylinder.
Feb 14, 2011 | 2006 Chevrolet Cobalt
1987 nissan pickup- clutch worked fine one day, next time the pedal went almost to the floor with no resistance, I had about 1" distance from the floor to disengage the clutch. checked the master cylinder...
sounds like your clutch master cylinder or slave is no good. do your self a favor and replace them both if you are going to be replacing them.
Sep 21, 2010 | 1987 Nissan Pickup
How do i get the slave cylinder out of the trans on a 95 saturn sc1
Unbolt the the two nuts that hold it onto the transmission. Then grab the slave cylinder and turn it counter clockwise and it should pop out. That is correct because holding it in the hole and turning it clockwise seats it back into the transmission.
Remember to remove the connection between the clutch pedal and the master cylinder or put a brick or something to hold the clutch pedal up or else removing the slave cylinder without the above note will ruin the hydraulics and allow air to get into this airless system.
Feb 26, 2010 | 1995 Saturn Sc
Clutch adjustment 95 Jeep YJ
no, there is no clutch adjustment. the clutch is hydraulic, and self adjusting, there are several things that can go wrong with these. with normal wear the fluid can run low allowing air into the system, causing a weak peddle. they can also develop leaks in the master and slave cylinders resulting in fluid loss also causing a weak peddle leading to an inopperative clutch. check the fluid level in the clucth master cylinder(next to the brake master cylinder. if it is empty, refill it(it takes brake fluid) then cycle the clutch peddle a few times and check for leaks. if there is air trapped in the line the clutch will need to be bled. there is a bleeder screw on top of the slave cylinder, bleed it just like bleeding brakes.
Apr 24, 2009 | 1995 Jeep Wrangler
Baby Gear Logo
61 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
