Question about RCA RT2280 System
Chk spkr I push the power button and it just says chk spkr and turns back off. can anyone help me please
  • Anonymous Mar 04, 2008
    I am also getting the message Chk Spkr when i turn my unit on, it will say that and turn right back off, does anyone know how to fix this?
  • josefran Mar 19, 2008
    I have the exact same problem with my system. Is there any resolve to this?
    President:
  • 624 Answers
That message means that you have a bad speaker or you have a bad amplifier IC most of the time. The amp circuit could have some other problem, but more times than not it is the amp IC.
How to check if it is the speakers or the amp circuit:
Unplug the speakers and turn it on. if you do not get the error message you have a bad speaker. If you do get the error message you have an internal amp problem. Then start plugging in speakers one at a time. If the unit turns on and stays on for a few minutes, turn it off and then plug in one more speaker. Keep doing this unit the unit gets the error message and when it gets that message you know that the last speaker you plugged in is the bad one.
Now the bad news
RCA no longer sells parts for their audio equipment. When the supply they have on hand right now is gone, thats it, no more RCA parts.
Now the good news.
The amp IC they use is a generic type that you may be able to get from another source.
But that is only good news if the amp IC is bad. It is the likely suspect, but without troubleshooting it on a test bench with the proper equipment, that can only be a good guess.
If you have found this help to you a good rating would be really appreciated.
Posted on Jun 22, 2008
What does it mean when u push the power button and the words ''chk spkr'' flashes on the display and still wont turn on??
The system connects to speakers with a certain impedance, i.e., 8 ohms, 4 ohms, etc. If you have connected the RCA speakers there may be a bad connection or the speaker(s) may be defective
Dec 08, 2012 | RCA RT2250 System
Deh 405 wire harness color codes. Need to know what each wire is to avoid incorrect hook-up. Thanks
These are the general wiring harness colors and their respective connections:
+12 Volt Battery Wire YELLOW (i.e. constand power for memory)
+12 Volt Ignition Wire RED (i.e. power only when key is ON)
Power Antenna / Amp BLUE/white stripe
Chassis (NEG) Ground BLACK
Front Left Spkr (+) WHITE
Front Left Spkr (-) WHITE/black stripe
Front Right Spkr (+) GREY
Front Right Spkr (-) GREY/black stripe
Rear Left Spkr (+) GREEN
Rear Left Spkr (-) GREEN/black stripe
Rear Right Spkr (+) PURPLE
Rear Right Spkr (-) PURPLE/black stripe
Cheers,
"If this has helped you, please rate this solution with thumbs up"
Jul 09, 2011 | Pioneer Car Audio & Video
CHK SPKR appears an turns off the system
It means to check your speaker connections for shorts.
Feb 19, 2010 | RCA RT2280 System
My kenmore dryer will not turn on
if it won't do anything, then first chk input power for 240 volts, then chk your neutral and two phase wires on the incoming power terminal strip, then check for a thermal fusible link,hi-limit switch,cycling switch,start switch(push button) or bad electronic control panel,all located on or inside the dryer
Oct 24, 2009 | Dryers
Speaker Problems
push the "sound edit" button on the remote, it will bring up things like, bass, center spkr, rear spkrs.. change the volume control on the rear spkrs.
Apr 09, 2009 | Samsung YP-U3 MP3 Player
RCA rt2500 "CHK SPKR" comes on when i turn it on.
"CHK SPKR" Check Speakers. Remove all speaker wires and turn on receiver. If it still says check speakers, you have an amp that needs output transistors or possibly just soldering of an emitter resistor but thats rare.
Dec 28, 2008 | RCA RT2500 System
Voice Mail
Your phone system time may be off in general. Have you checked that?
You can usually reset the phone time display form the main console
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From Front Desk Phone
1. Push Spkr button
2. Enter #652
3. Enter Correct time in HHMMSS
4. Push Redial button
5. Push Spkr button
Nov 07, 2008 | Toshiba DKT-2020 Corded Phone
Connecting a car radio
Hi Manny,
For a Panasonic CQ-DP7838EU, the wiring would be:
yellow - to the always on B+12 like the + terminal of the battery;
red - to the ACC of your ignition switch (there is a 1Kohm resistor);
black - chassis ground (negative terminal of the battery);
dark blue - goes to a motorized power antenna;
orange - goes to the mobile cellphone;
white - front left spkr +
white w/ black stripe - front left spkr -
gray - front right spkr +
gray w/ black stripe - front right spkr -
green - rear left spkr +
green w/ black stripe - rear left spkr -
violet - rear right spkr +
violet w/ black stripe - rear right spkr -
Hope this be what you need. Pls post back how things worked out or should you need additional information.
good luck and kind regards.
Dec 09, 2007 | Car Audio & Video
Chk spkr error message
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Jun 22, 2006 | RCA RT2280 System
RCA RT2280 System Logo
485 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
