Question about Boss DVD-2000 Car DVD Player
The player plays the discs, but I can't get the sound.
    New Friend:
  • 25 Answers
See if you can get sound out of the am/fm stereo. if not, the audio output ic is bad and it's located on the big heatsink in the back of the unit. you will have to take the unit apart and unsolder it to remove it.
Posted on Jan 29, 2010
SOURCE:
No picture, no sound
see the troubleshooting index:God bless you
No sound
1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
2. Check if the TV, DVD player and Amplifier are connected properly.
3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Apr 11, 2011 | Vizio VBR231 Blu-Ray Player
All discs will not play. Sounds like it is trying to play ...
try cleaning the OPTICAL lens directly with a Qtip , gently clean it from any debris , and try again , the procedure shouldnt be hard to open it up , good luck ,
thanks AJ
Nov 15, 2009 | Sony DVP-CX777ES Multi-disc DVD Player
I HAVE A DISC IN U.K. AND EUROPE REGION . BUT CAN'T PLAY MY DVD PLAYER. HOW CAN I PLAY THE DISC IN OUR PLAYER? MODEL IS DVP 3256 ,DVP 3258,DVP 3268 . WITH USB . ANY OPTION TO PLAY THE OTHER REGION DISC....
HELLO
This sounds like the old problem of your player trying to play a disc from another region, when your player is set for another. What you need to do is HACK the player and set it for ALL REGIONS (0), usually via the remote control.
Try this website for DVD player hacks: www.videohelp.com
You will find hacks for many makes and models listed here. Contrary to belief, it is NOT illegal to hack a DVD player.
Aug 03, 2009 | Philips DVP3960
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Sony MiniDisc car stereo
It sounds like you have a newer portable minidisc player, and an older deck. There were several upgrades over the years for ATRAC files, and some of the newer recording formats are not compatible with older players.
Nov 10, 2007 | Pioneer MEH-P5000 MiniDisc Player
Boss DVD-2000 Car DVD Player Logo
Top Boss Car Audio & Video Experts
Marvin
Marvin
Larry Tezekjian
Larry Tezekjian
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
