Question about Mitsubishi HC3000U Multimedia Projector
Mitsubishi hc 3000 projector
1 yr old projector, picture is still good except multiple horizontal lines appear.
  • 682 Answers
Http://www.projectorcentral.com/pdf/projector_manual_3026.pdf.
if you go to manual above page 26 you will find it normal thing.
Posted on Mar 17, 2008
Mitsubishi HC 5500. While playuing the picture disappears. No picture only sound, also status and power lights start blinking red and green
Red and Green bliking with no picture means a service problem. But you might try cleaning the filters first and being sure that nothing is blocking air flow through the projector. Red status solid means replace the lamp, but that doesn't seem to be the indication.
Feb 09, 2011 | Mitsubishi HC5500 LCD Projector
My 3 yr old tv has developed lines in the picture.
remove set back find large transformer with red wire attatched to pix tube find control labeled G2 reduce slightly wit set on with no sgnal on avideo inpt
Mar 11, 2009 | Samsung TX-R3079 Television
Mitsubishi Model CR3515R White Gray lines cause picture inversion.
Your having trouble with the vertical sync/deflection circuitry. Probably a driver since it clears up after it gets warm. Could be as simple as a cold solder joint but it's not something you can do yourself unless your a tv repairman.
Sep 24, 2008 | Mitsubishi CS-40503 TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Jan 22, 2008 | Sony VPL VW10HT Multimedia Projector
MITSUBISHI HC 100 PROJECTOR
Hi there
First try to bypass the box and put signal directly into the Projector from the source - i.e. DVD Player
If the signal still doesn't pick up , try using a different cable.
If the problem is solved , then your Converter Box is faulty.
If the problem still occurs then you might have a faulty Mainboard - as all the inputs on this Projector is situated directly on the Mainboard.
Hope this will help you !
Jan 03, 2008 | Mitsubishi HC100U Multimedia Projector
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi HC3000U Multimedia Projector Logo
288 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
