Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Oven shuts off after 3 min
My GE spacemaker oven shuts off after 3 minutes when cooking on high, then resets itself 10-15 min later.
I don't think that I hear a fan spinning when the microwave is on - could it be overheating? If the answer is yes, how should I repair this?
Thanks Appliance Experts!
Jeff
  • 3 more comments
  • Anonymous Feb 20, 2008
    I have the same problem! Any ideas?
  • martyb704 Feb 27, 2008
    My microwave basically starts to work and then shuts off as if there was a power failure. It comes right back on but asks you to reset the clock, etc. It makes for a nice built in clock but a terrible microwave as it won't run long enough to cook anything.
  • Anonymous Apr 01, 2008
    My GE Spacemaker worked fine for about 1 year. Now it turns off around 3 mins and restarts after an hour or so.
  • Anonymous Mar 19, 2014
    bought and installed a used 10 year old working ge oven/mircowave unit; we use the microwave one and the board keeps shutting itself off; could we have fried the board? How is tat possible?
  • Anonymous Mar 21, 2014
    Microwave shuts off after 2-3 minutes and doesn't come back on until 15 minutes later. Any ideas?
Had one of these brought into shop. Customer complained it would run for 3 minutes (on high), then would shutdown and clock would reset. We noticed that there was no fan sound coming from it when we first ran it. Bingo! found magnatron cooling fan blade came off the motor shaft. After getting into it, found that there was no E-clip or any other fastener. The blade was glued on only. So we used a two part 5 minute epoxy glue and reattached, let glue cure and ran repeatedly to make sure no damage had occured to Magnatron or supporting components. All is well now! Hope this helps someone.
Jay
Posted on Apr 09, 2008
  • konnoclan Jul 19, 2012
    I am having this problem too. Can it be fixed without taking microwave down from cabinet? Are there any parts I should have on hand before attempting the repair?
I have a GE microwave oven I purchased at Wal-Mart for ( I think) $50.00. It started shutting itself off after a few seconds, and got progressively worse.
I opened it up and noticed a temperature switch on the magnetron. This switch interrupts power to the whole unit when it opens on high temperature.
I jumpered the leads (bypassing the temperature switch), and it ran fine for a minute with a coffee cup of water for a load. Before it would switch off after only 5 seconds.
Yes the magnetron gets warm, but how warm is normal? I don't know. It felt like about 150 degrees F to me after a minute's operation.
The temperature switch has the numbers "150" stamped in it, so that may be 150 F or 150 C. I'm guessing 150 C, which is about 300 F
I thought "maybe the temperature switch is just getting weak". I noticed a second similar temperature switch on the far side of the microwave, where the air exits the oven. It had "100" stamped in it, but just for laughs I swapped it with the "150" switch mounted on the magnetron.
Well ,it works great, with my test of heating a coffee cup full of water for a minute.
I will shop for a proper replacement temperature switch. Meanwhile, I can get some limited use from my microwave, under a watchful eye of course.
Posted on Mar 23, 2008
  • GE Master
  • 9,098 Answers
TO RYNEAU:
The cooling fan is critical! If the magnetron overheats too much or too often, it can fail, and that adds to the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
TO MARTYB704 & GUEST:
I think you have a different problem than Ryaneau.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got
pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying
for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Mar 04, 2008
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave was not heating a frozen meal properly then all power shut off. A few minutes later power came back on with "reset" showing in window.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfsgh
Jul 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven shuts down when set at high a high cooking number. I must wait a while before it can used again. I have a GE spacemaker
It may be that your magnetron is overheating, which will trip the magnetron's thermostat, which will interrupt power until it cools down a few minutes later.
Or it may be a defective magnetron causing electrical interference that disrupts the control circuit.
In order to help you, we need your full model number and some further information.
So please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
- How long does it cook before it shuts down?
- When it shuts down, does it go completely dead, or does it just stop with the display still lit?
- When you try to cook, do the inside light, turntable, and internal cooling fan all come on?
- Is it making any unusual noise?
- Is it louder or quieter than usual?
Oct 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 - Automatic Fan
Hopefully steam didn't get up into it. Apparently it was the heat, but it may be miswired or have a defect in the hood thermostat or on the controller. I always recommend using the hood fan when cooking on the stove top or in the oven but that may have been irrelevant here. I would definitely recommend calling the GE Answer Center at 1-800-626-2005 on this one. If the installation was done correctly, then an exchange may be in order. Early in the warranty, you should be very demanding!
Dec 26, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
780 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
