Question about Lands Phones
My phone keeps saying, connecting, connecting, connecting, but no dial tone comes up, and says unavailable, what is the problem
Ecx550 uniden what do you want me to say, it is a black phone and has
a answering machine and will not get a dial tone on the phone #2
but will get one on the phone with the base
  • Anonymous Feb 29, 2008 phone keeeps telling me connecting..connecting and no dial tone...
I searched for ages before I found the solution to this. Just plug the 2nd handset into the base station as though you were charging it. You'll see the red light in front flicker for a few seconds. Wait five seconds after it goes solid red again and remove it. Press the "find phone" button on the front of the base station. If both phones beep, you're all set. If not, rinse and repeat.
Full owner's manual is here:
Posted on Feb 01, 2009
  • 38 Answers
Do you actually have a 2nd line number wired at the jack you are connecting the phone to.Try phone 2 to prove this. If these requirements are met, make sure you have 4 conductor cord and it's plugged into the proper jack in the back of the phone that doesn't work.. Thank you. Jerry
Posted on Feb 17, 2008
No dial tone on line 2
Feb 27, 2014 | Uniden DECT4086 Cordless Phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I completely reset, and remove all settings from my Uniden Tru-8865 cordless phone?
When I try to us my phone to make a call it says connecting there is no dial tone then is says unavailable
Nov 14, 2009 | Uniden Cordless Phone
Phone showing "unavailable" and there is no dial tone. I have tr
Unavailable and no dial tone usually means that there is a bad wire between the base and the wall or the wall jack is bad.
Jun 27, 2009 | Uniden Cordless Phone
Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Mar 10, 2009 | Uniden 2.4 GHz Cordless Phone System
No dial tone on headset 2
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
Jan 23, 2009 | Uniden 5.8GHz Cordless Phone
Phone problems
I'm unable to get a connection on my phone when i press the talk button is says connecting and then it states unavailable.
Mar 23, 2008 | Uniden Cordless Phone
Uniden cordless phone
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
Feb 18, 2008 | Uniden Cordless Phone
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
Lands Phones Logo
804 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
