Windows startup error
Whenever i am starting the Laptop it shows a blue screen with the message--- "windows shut down to protect your machine from damage, press F8 and go to safe mode to remove a newly installed hardware or software, ......"etc.
and at the end of the screen its written
technical information
stop :- 0x0000C1F5(0x00000000, 0x00000000, 0x00000000, 0x00000000)
i tried but it doesn't allow me to enter in safe mode with F8 or even recover the system from the recovery cds
  • 1 more comment
  • diwakar kinkar Feb 22, 2008
    whenever i am starting the Laptop it shows a blue screen with the message--- "windows shut down to protect your machine from damage, press F8 and go to safe mode to remove a newly installed hardware or software, ......"etc.
  • Anonymous Mar 12, 2014
    i tried to put a shortcut to yahoo mail on my desktop it put a sm This content cannot be displayed in a frame To help protect the security of information you enter into this website, the publisher of this content does not allow it to be displayed in a frame. What you can try: Open this content in a new window this contentall window This content cannot be displayed in a frame To help protect the security of information you enter into this website, the publisher of this content does not allow it to be displayed in a frame. What you can try: Open this content in a new window this content this is locked and i cant remove please help
  • Anonymous Mar 27, 2014
    At first when i installed windows 7 i installed it on a 32bit but after the screen turned black i folowed some instructions on the internet where they told me to shut down the laptop, take out the battery remove all the stuf that was connected then i hold the power button for 15secs and then plugged in the power supply and turned on the laptop the screen was still black but on the external monitor it showed that it was searching for problems because windows or the laptop did not shut down correctly after the scan the man had to press the finish button so that the windows can start normally but when everything loaded on the screen everything was different and the operating system was not on a 32bit anymore but a 64bit so now i don't know what to do!!!
If it is Windows Vista and it happened after a Windows Update, you might have the problem as described in Microsoft Knowledge Base article KB946084. No matter what you do (any F8 option such as Safe Mode or Command Prompt, or trying to boot from a Vista CD) you end up at the Blue Screen of Death.
Something is corrupted on the hard drive (not a hardware error) and now Vista has a fit if it sees the drive, even as a secondary or external drive (it goes to the BSOD with STOP: 0x0000C1F5).
The only solution so far is to erase the Vista partition and re-install Vista. You can take the drive and connect it to another computer running XP (using an external drive enclosure for example) to get the data off of it. Then do a format on the partition. Now reinstall the drive and you can load Vista. If you have no Vista disk but there was a Recovery Partition, this will now work.
Posted on Mar 19, 2008
  • SemiTechGuy Apr 10, 2008
    Someone found a method of fixing this problem. I have not tested it yet but Google "Galactic Toilet" and "0x0000C1F5" to find the link. It describes using the SystemRescueCD (a Linux based Live CD) to fix this problem.
    Genius:
  • 1,665 Answers
With WinXP operating system, after pressing F8, you may select also "Last Known Good Installation" instead of " Safe Mode" which drives you in an easier problem solution.
If problem perists better boot from cdrom with original operating system cd in begin win setup and follow instructions intstalling over the previous installation.finally let automatic microsoft updates "on" to have your laptop up to date.
Good luck.
Posted on Feb 22, 2008
I lost my password on windows xp, how can I get back on the administrator screen instead of guest screen.
Posted on Feb 17, 2008
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
Jul 18, 2009 | Computers & Internet
Blank/black screen at power on
This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
I hope this will fix your problem.
Mar 17, 2009 | Dell Inspiron 6000 Notebook
Computer windows will not come up
Try This:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Blue Screen of Death during startup
When you get the BSOD - it gives a brief description of what the error is - this should lead you in the proper direction for finding the culprit - is the computer a new configuration - is it an old system that just started doing this? Have you made any change? All these things have to be considered and evaluated.
Nov 19, 2008 | Dell Inspiron 6000 Notebook
Pc will not go to "sleep" Blue Screen
try reinstall whole system but don`t forgot do back up first ;)
Aug 13, 2008 | Computers & Internet
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Jul 10, 2008 | Compaq Presario 700 470024-192 Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
231 people viewed this question
Alun Cox
David Payne
David Payne
