Question about Saeco Vienna Espresso Machine
Saeco Vienna wont turn on
Cleaned brew group reinstalled and now the unit wont turn on after numerous times open closing reinstalling UGH!
  • Gio Dease Feb 17, 2008
    I will try again, first try and still no worky! I just want a coffee!
    Thanks Pierre235, I will take some deep breathes and wiggle some more!
  • Anonymous Apr 28, 2008
    It started to grind coffee when no one was in the room. Turned machine off and it will not turn on.
    What do I do???
  • 2,039 Answers
Dont worry if it was working good before the clean up the brew group is not install all the way in remove it push it in untill you here a click the brew group is not all the way in and doesnt push the on switch when you push it in wiggle it
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 17, 2008
  • pierre laplante Feb 18, 2008
    like i said if it was working before there nothing else then the brew group if you clean and move the inside of brew group on the brew group the main hole were on the side you suppose to have and arrow .the arrow must aling to the mark if not aling the group wont go in wont push the switch wont go on im sure its that
    PIERRE
My descaling and coffee grounds drawer light were blinking alternatively. I did as the instructions said and turned the machine off then back on to no avail. So I removed the grounds drawer and brew...
Make sure the brew group is in
rest position; the two references
must match.(look at the marks/arrows on the side of the brew group)
Make sure the components are in
the correct position.
The hook shown must be in the
correct position; to check its
position, firmly press the "PUSH"
button.
Jan 14, 2011 | Saeco Odea Giro Plus Coffee Maker
Vienna Black suddently stopped working. No lights or anything.
the grinding noises are worrisome. Sounds to me as though something was in the wrong place, and once it worked for one cycle, whatever was left inside, or ??? would have frozen the unit. Sounds to me like you'll need to take it completely apart, to see what's causing the lock up situation.
Jun 01, 2008 | Saeco Vienna Espresso Machine
Red light from the coffe keep blinking
make sure all the doors are closed, brew group, tray, water, and disposal are all seated closed.
have you cleaned the brew group? something stuck in the grinder? got beans and water?
Sep 19, 2010 | Saeco Vienna Espresso Machine
My Vienna Digital suddenly makes weak coffee and it not hot
Try resetting the maching to factory settings.
Here is another question, bear with me, what do you brew the coffee into? And is it pre-warmed?
Jun 08, 2009 | Saeco Vienna Digital Coffee Maker,...
Need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Apr 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna deluxe brew group was jammed
If you have the box the machine came in there is a key that kinda looks like a wine opener, use that to set the little arrow on the brew unit to the "N" letter, then the unit will fit into the machine.
Dec 26, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Saeco Vienna Espresso Machine Logo
361 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
