Question about Soltek SL-86SPE2 Motherboard
One Beep after Checking NVRAM...Update OK
After Checking NVRAM...Update OK I hear one long beep and then system goes into Windows.Is this beep normal to hear?
Windows XP Pro
SL-86SPE2-L
P4 2.4Ghz, FSB800
2 X Kingmax Superam 1Gb
GeCube ATI Radeon X1600
Maxtor Diamondmax 9, 120Gb
Creative Labs Xi-Fi
  • Anonymous Feb 18, 2008
    I'll try to give some more information;
    when I press the power button 1 short beep and at the end of the POST
    i got this massage,
    Checking NVram...Update OK
    007C
    0085
    50AC
    and then 1 long beep.
    After
    that goes into Windows.I don't see any stability problems or errors
    while working in windows.This is happening during every boot.
    Could this 1 long beep be problem with system Memory or EEPROM chip ?
    Should I be worried about motherboard,'cause if its system memory problem, that can be fixed with installing new memory chips,but motherboard with s478 would be much harder to find.
    System:
    OS: Windows XP Pro SP2
    Soltek SL-86SPE2-L [ AMI Bios AF1.8 ]
    P4 2.4Ghz FSB 800
    2 x 1Gb Kingmax Super Ram PC3200
    Maxtor Diamond Max 9 Plus 120Gb
    GeCube Radeon X1600
    Pioneer DVD-119
    Pioneer DVR-109
    Creative Labs Xi-Fi
    Genius:
  • 1,019 Answers
The Computer generates 1 beep. to state that the computer has set itself up properly, without errors. Depending on the bios manufacturer. i.e Pheonix or AMI et,c.
As long as your system is running fine with no crashes or errors.
Then this seems perfectly normal.
Posted on Feb 17, 2008
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
Memory not being properly identified or used
4-3-1
Memory failure above address 0FFFFh
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
Tip
Beep code and their meaning: 1 short beep Normal POST - system is ok 2 short...
beep code and their meaning:
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
on Sep 07, 2013 | Computers & Internet
When i start my computer it makes a loud beeping noise it is a acer aspire4520
What you are hearing is probably a BIOS beep code.
Beep codes are a bit like Morse code, and are used to indicate certain faults with the hardware.
The codes change from manufacturer to manufacturer, but generally speaking one beep = System OK, so if your PC is starting up normally and you have no other problems there is nothing to worry about!
Hope this helps,
Matt
Jun 08, 2010 | HP Pavilion dv6000z Notebook
My ps3 turns on but only the theme background appears it turns on and it says ps3,that goes away and when the icons should be coming up,they dont! help please!!
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 24, 2009 | Sony PlayStation 3 40GB System
Update stops at 52% on my PS3. ERROR CODE 8002F147
also the last part of an update is flashing the blu-ray drive so if the blu-ray drive is dead or unplugged it will fail at end
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My PS3 has no menu. No sound or video
try video reset
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
My ps3 has a fuzzy screen when playing on it this only happened a few days ago should i tae it back as it is only 4 weeks
first try video reset
then take it back as these steps will not void warrenty
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Soltek SL-86SPE2 Motherboard Logo
1,484 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
