Question about Simplicity for Children Ellis 4 in 1 Sleep system 8674 Crib
The mattress brackets
Hi my husband and i are putting together the crib and we cannot get the mattrees bottom attached to the crib itself. We are putting the brackets on like the manual says but it appears to be too big. It will not fit into the holes on the inside. We have the simplicity ellis 4 in 1. Thank you for any help you can offer us.
  • 5 more comments
  • sarahmac7 Mar 03, 2008
    We are having the same problem. so you attach the brackets with the circular opening or the oval opening?
  • Anonymous Apr 06, 2008
    Back of crib is too long to mount mattress support. Tube is too short or rear support is too long.
  • daddytobe Apr 21, 2008
    I have solved the mattress bracket problem!! The instructions say to install them so that the oval hole attaches to the wood of the crib and that the circle hole attaches to the threaded bars in the mattress support assembly. It should be the exact opposite. Otherwise, there is too big a gap between the crib and the mattress support assembly. After you switch the brackets, you may need to use longer screws than what the directions say to use. They say to use the L screws, which are short (ours had some blue on the threads) but we had to use two L on one side and two i's (longer screws) which we took from the extra set of hardware for whenever the crib can be switched to a day bed. We spent a long time trying to figure this out and it was not cool of the company to mess up so badly, but hopefully if you read this article, your problem will be solved.
  • Anonymous May 06, 2008
    Good lord! You would think they would attach a new supplemental sheet to all the stores or have info on thier hotline or website. GRR Thank god for this site!
  • Anonymous Aug 30, 2008
    can't put together
  • mpalmernyc Sep 27, 2008
    I was pretty disappointed when I encountered this problem and got excited when I found this site and thought my problems were over. However I was even more disappointed to have people on here say how they called customer service and they were sent instructions and pictures and it worked perfectly, yet they failed to share any of it. I personally think the idea of switching the brackets around contrary to the instructions is a bad idea. The notch on the round hole end secures into the pole to keep it secure, switching it around will make it unsecure in my opionion and I think it would damage the wood as well.
    I tried to call the company, however it was Friday night when I started and can't in good faith leave it uncompleted till they open on Monday. I was tempted to just go out and find 2 wooden blocks that would cover the gap, I still think that would work, however I didn't do it. Here is what I did.
    I just loosely put all 4 screws in, then tightened the rear brackets into the wood first, then just went ahead and screwed in the front ones. The brackets had to bend a bit to cover the gap, but they don't seem to be under too much stress. In the end it seems pretty secure to me. I do plan on calling the company when they open on monday, and if they give me some simple fix I will be sure to come on here and share with the rest of you.
  • thubbard1 Nov 08, 2008
    I'm attempting to attach the bed frame of 4-1 crib. The two poles are too short to attach on both ends. Am I the only one with this problem? I'll be calling custmer service Monday but if someone can assist me with this before Mon. it'd be greatly appreciated.
Posted on Sep 27, 2008
Had the same problem. Even called Simplicity and was emailed some pictures which helped a little bit. Basically the brackets have to be installed on the correct sides, they are not interchangable. they should be labelled left and right. we had to trial and error moving them around until we were able to have them all facing in a direction that aligned the front and back of the mattress support bars most in the middle. then we were able to use the correct screws, and by half tightening both the front and back together the gaps pretty much disappeared. It's not easy though. Using longer screws is an easier fix, but I was worried that not assembling the crib correctly might lead to safety issues.
Posted on Sep 03, 2008
In order to make this work, you must switch the way the directions tell you to put on the brackets. The oval part attaches to the wooden crib while the round part screws into the mattress support assembly. There will still be a significant gap between the wood and the metal bracket, so I had to use longer screws (the i's) in order to make it work. I used two shorter screws on one side (L) and the longer ones on the other side. Seems to work, but the directions are WRONG! I hope you find this answer before you've spent too long trying to figure it out like I did.
Posted on Apr 21, 2008
This is intended for the Simplicity Ellis 4-in-1 crib not the Aspen. My hubby just put together the toddler bed, and he had a problem with securing the screws of the metal mattress support to the crib. He put the screws one by one and there was a gap of nearly 1/2 inch from the crib. He resolved this problem by putting the screws on all four ends of the mattress support, then he tightened the back rail screws (the higher end) first and when he tightened the front rail screws the gap automatically disappeared. I hope I am clear enough on this as I'm not the one who installed this crib, but as he was quite frustrated I thought this might be able to help others who may have the same problem.
Posted on Mar 11, 2008
  • 33 Answers
Looking around there are many complaints about the assembly directions being very poor.
A couple notes that may be useful:
"there was nothing in guide to tell you to bolt in bottom part of back rail, which is kind of common sense but should be defined"
"one call to an outstanding customer service rep and it was together in no time"
" My husband and I were trying to figure out these instructions for an hour!" Yikes!
Everybody says they ran into problems with those brackets, but they were able to figure it out on their own because they only fit one way, but it's not really intuitive or specified well in the instructions. But once you figure them out they are quite sturdy and fit nice.
I can't find anyone who actually explained how they got the brackets to work however...
Posted on Feb 17, 2008
Lowering crib mattress
What is the exact make/model of the crib? Did you just purchase it and put it together?
Thanks,
Lee
Jun 17, 2008 | JCPenney Basic Crib
Need assembly manuel for Jenny Lind 012614 where can I find it online?? Every website takes me to another I am very frustrated....didn't think it would be such a ordeal to locate a manuel online???? Is...
Evenflo Jenny Lind Crib has been recalled.
When you call to get the kit to fix the problem (800) 356-2229 you could ask Evenflo directly!
Here are instructions without a manual...
1. Lay the headboard on the floor in front of you with the bracket holes and model number facing you. Use 2 ¾-inch wood screws to attach the L-bracket and the latch bracket to headboard. The L-bracket has 3 holes and attaches to the holes on the lowest section of the headboard. The latch bracket only has 2 holes and goes directly beneath the metal bracket for the mattress that is already attached. It should face toward the center of the headboard. Once you're done, complete the same procedure on the right side of the headboard. Then do the same for the footboard.
2. Stand the headboard up so you can attach the rails to it. First, place the cross dowel (the small piece of wood with a hole in the side of it) into the hole on the underside of the top rung of the rail. Then put a second dowel in the top side of the bottom rung. Line the left rail up with the headboard at a 90-degree angle, placing it in the brackets you just installed, and insert a 2 13/16-inch machine screw into each of the 2 holes on the front side of the headboard (the side that will face outward). Tighten each screw with your screwdriver until it hits the cross dowel. Then turn the cross dowel clockwise to lock it in. Do the same for the right side and then for the footboard.
3. Slide the mattress platform (the bottom of the crib) into the stabilizer rails (easy to distinguish, since they are the same size as the sides of the platform), putting the longer ones on the sides and the shorter ones on the ends. It will slide in easily. Use 5 ¾-inch screws to attach the hanger brackets to the corners of the platform. The holes are predrilled and you can only put the bracket on one way to match them up, so there is little worry that you will attach it wrong.
4. Put the support brackets (the straight, flat ones) on top of the predrilled holes in the underside of the stabilizer rails. Screw them in with ¾-inch wood screws. Then place the hanger brackets in the slots that were preinstalled on the headboard and footboard. Choose the level that will suit you best. Evenflo recommends the top two for infants.
5. Snap a caster (the round disc) on the bottom of each foot of the crib. Check that all your screws are tight to keep your baby safe.
Jan 29, 2011 | Evenflo Jenny Lind Crib
I need to lower the base to its lowest setting but not sure how ?
Remove the mattress. in all for corners you should see metal arms that are attached to the mattress support. these arms will be screwed into brackets on the crib. Unscrew all four screws and re-screw them into the lowest hole available. replace mattress and your done.
Jul 10, 2010 | Baby Gear
How do I assemble a Bassett crib model 5096-0505? I think I have all the parts. this includes a headboard, footboard, spring mattress support, mattress, two long iron rail support brackets, two sides, four...
where's the manual?
you can assemble it immediately!
have u lost the manual?
you can find the manual here:
Please use the form below to send us an email.
Infant furniture questions to juvenile@bassettfurniture.com
hope you could come to this sites there are many related manners all about mattress:
http://www.bestmattressreviews.com
Dec 06, 2009 | Bassett Mission Crib
Have a Lullabye Crib - 28 yrs old, no instructions for reassembly
I have directions for the Lullabye Princeton Crib, Model 311146
that I purchased in 1993. It sounds like the same type of hardware
that allows the front rail (only) to move up and down, with springs
at the bottom to cushion the drop. If you think this might help you
and you want me to post these directions, just let me know.
Nov 19, 2008 | Baby Gear
Can't put back together
It is very difficult. My parents and I spent about 3 hours on it, and my husband came home and did it in about 5 minutes. You have to actually put the hard-wood board and frame part in the liner. You have to pull it really tight, and the bit of printed material with the Warning sign should fold from the outside in. This puts the ruffle part close to the top--but on the outside. The buttons will snap all around, and the strappy things on the bottom hook around that bottom basket part and snap. You will be able to see the wood before you put the little mattress back in. I really hope that helps--we were so frustrated.
Apr 21, 2008 | Kolcraft Tender Vibes 18189-TX Crib
Kinderkraft crib
You just take the drop down side off and put the mattress at the lowest setting. We have the same crib and used it for a few months as a toddler bed.
Jan 11, 2008 | Kinderkraft Vermont Crib
Misplaced parts
On the piece that supports the mattress, there should be a piece of paper attached to it. On there is a phone number, fax number, model number, order number, order date, and country the crib was made in. The phone number on mine for DELTA customer service is 718.385.8453. I don't know if it's still valid since my crib was made in 2004. However, it should give you a start. My husband called there two years ago and got new screws and things for our crib when they were lost during a military move. I hope this helps.
Jul 28, 2007 | Delta Luv Jasmine 4852 Crib
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
Simplicity for Children Ellis 4 in 1 Sleep system 8674 Crib Logo
737 people viewed this question
Top Simplicity for Children Baby Gear Experts
Marvin
Marvin
Joseph Hoffmann
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
