Question about Acer Aspire 1690 Notebook
Speakers I do have 2 Aspire 1690 and at both of them the internal loud speakers stopped suddenly since then I had to use external ones. Can u fix the problem?
  • purwanto Nov 21, 2008
    I have same problem with same laptop
    Master:
  • 474 Answers
If they just Suddenyl stoppe din the middle of listening then theres probably a hard ware problem and you cant really fix a audio card in a laptop becasue its all built into the mainboard so your probably out of luck.
Im asumeing you checked all the audio settings.
Sometimes on the inside of the laptop the speakers plug into the mainboard with a little wiresing harness that clips on, it may be that it jarred loose, you could try taking the laptop apart and messing with it, but only if you are confident in taking a laptop apart. Theers alot of lisstle plasice pieces and fragile parts inside that dont take kindly to being tugged or pulled on.
Posted on Feb 17, 2008
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
I have a SONY VAIO VGB-140E. Using the external speakers, the sound is working. The internal speakers sound is suddenly stop working. I did re-install the sound drive and also did a system restore but no...
go into your sound driver options and locate the speakers you are trying to use, weather it be external or otherwise. Make sure the volume is up (i know obvious but still)
rate yea?
Jul 08, 2011 | Sony VAIO VGN-NS140E/S Notebook PC
Hii sir ,,,my problem is intenal audio speakers is not working......bit working for external.......this cause a huge problem to me...........sir show me the solution...............
If your external speakers are working and your internal ones are not then it's either a loose connection with the internal speakers or the speakers themselves are not working anymore.
I would try the following; check for viruses, spyware, and malware. Reboot the system afterwards. Reinstall the sound drivers and make sure the soundcard is enabled. If all this fails then you have three options.
1. Order a set of speakers for your system and install them yourself.
2. Have a tech or pc repair shop replace them for you.
3. Continue to use external speakers.
Good Luck!
Aug 19, 2010 | Aspire Acer 4720-4538 Notebook PC
My internal speakers for my Acer Aspire have suddenly stopped working. However, when I plug in my external speakers, there is not problem. Please advise. Thanks
Go into the speaker icon in the bottom right hand corner of the screen and click on it and get to the mixer. In there make sure the speakers aren't muted.
If it is muted then click on it to unmute it and you should have your sound back.
If you don't have your sound back then that means either the speakers are bad or because the internal speakers hook up to the motherboard, the mohterboard could be bad.
Jan 23, 2010 | Acer Aspire One PC Notebook
Subwoofer won't work plugged into Acer laptop
i have an aspire acer 5735z laptop in the manuels it says its possible to have a video confrence,but when using msn messenger it says no webcam has been installed..how do i find or locate the webcam,if their is one at all?
Jun 16, 2009 | Acer 90.00012.30B Computer Speakers
Acer aspire1690
Your screen sounds fine, most likely just your backlight going out, either that or you could have hit the key for using an external monitor (function f6 is the LCD/external monitor switch for my computer). I'd look into the function f6 and play around with that, if not you can just buy a new backlight from ebay or an internet supplier.
Jan 21, 2009 | Acer Aspire 1690 Notebook
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
No sound coming out
sure..the speakers are toast, or the connection is fractured. You may be able to inspect the connection by removing the keyboard, but it's usually buried under the palm rest.
got backup?
Feb 12, 2008 | Acer Aspire 1690 Notebook
Acer 5610 sound problems
Hi, It is possible that: 1. You may have recently installed an add-on/external device such as a multimedia keyboard which changed the audio output from internal to external; 2. The laptop's internal speaker might have gone dead (highly unlikely but still a possibility) - try plugging in external speakers or a headset and check; 3. Most if not all laptops uses a female stereo babyphone jack to connect to external speakers. This jack has a built-in switch that cuts off internal speaker if an external is plug in. If you are using eternal or headset from time to time, it is possible that the switch might have locked to external and does not switch back to the internal; 4. You may have a hardware issue specifically the sound card/chipset. This of course would require an inshop repair which may be better off with an authorized service center. At worst is have the entire laptop replace if it is confirmed to be a hardware issue. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 09, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 1690 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
