Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
MITSUBISHI WT-A42 ERROR CODE 22 "SHORT PROTECT CIRCUIT"
WHAT DOES THAT MEAN? AND CAN I FIX IT MYSELF? MY TV TURNS ON AND 2 SECONDS LATER,SHUTS OFF
  • 4,889 Answers
Error code 22 is a short protect circuit. this means the tv has found a problem in the tv and will not let it turn on till fixed. this could be several different circuits in the tv that is causing this. we need to test some parts to see what this is. the most common is a shorted convergence circuit. a repair on this would range around 400.00. You should check using a multimeter and also you should be good at soldering
PS:I strongly advice if you don't have experience in electronics then better leave this job to a tech
Posted on Feb 17, 2008
  • Mitsubishi Master
  • 19,396 Answers
Error code 22 = a short protect circuit
  • Ginko
    Ginko Feb 17, 2008
    The tv has an electrical problem inside . Try disconnecting it from power (unplug cable completely) for 10 minutes if you still get code 22 after turning it back up, then there may be a major problem.
    Genius:
  • 3,422 Answers
error code 22 is a short protect circuit. this means the tv has found a problem in the tv and will not let it turn on till fixed. this could be several different circuits in the tv that is causing this.. the most common is a shorted convergence circuit. a repair on this would range around $400.00.
the fact it did this when the box shut down is odd... but i see no way it could have caused this.
Here are few trouble shooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck..
  • 689 Answers
The error code 22 is a short protect circuit. This means the tv has found a problem in the tv and will not let it turn on till fixed. this could be different circuits in the tv that is causing this. we need to some parts need to be tested. the most common is a shorted convergence circuit. It requires hands on electronic repair skill. If you have done electronic repair I may give you some guidelines, I you don't have experience on electronic circuit repair, I will strongly recommend you to take it to a service center or ask a hands on technician's assistance as it requires circuit diagnostic-troubleshooting after opening the back cover. Please post if you have further questions.
Good Luck
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Was working fine now will not turn on
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
SD TECH
Jun 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Turns on for a couple seconds and immediately turns itself off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
Let me know what you find and I will tell you what I know.
SD TECH
May 10, 2010 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mistubishi 42" turns off at turn on.
Chassis VK-20 made in 2002
http://www.techlore.com/downloads/file/7714/WT-42311,_WT-A42.pdf
The service manual can be downloaded here, you will need the free adoe acrobat reader from adobe.com(You Probably already have it)
error 22 says SHORT PROTECT CIRCUIT in the service manual, it has all the wiring and board diagrams as well as replaceable parts and part numbers
Please give me a good rating if this helps you solve your problem, or if this was what you were looking for which I believ it is.
PLEASE KNOW THAT SOME CAPACITORS INSIDE THE TV WILL CONTAIN FATAL VOLTAGE EVEN AFTER UNPLUGGED.
Extreme caution should be taken, death has occured often from inexperience, so please be warned, and understand that neither I or Fixya.com will be held liable for how the info is used, I will only put this into solutions that involve products that can be deadly if serviced wrong.
Thank you very much for the question, I hope this is what you wanted.
Apr 11, 2009 | Mitsubishi WT-42315 42" TV
Error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
Mar 08, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Error code 2-2
error code 22 means short to ground. for a start check your power supply to see if anything is shorted to the ground.
Oct 14, 2007 | Mitsubishi WT-46809 46" Rear Projection...
TV Shutdown
Mitsubishi's have an error code system (press both menu and input/device buttons on the front panel, the green light will flash a 2-digit code...(example one flash short pause two flashes=12 long pause then it will repeat four more times...error 12 is no problem found...the other codes are 21,22,23 and 24.........Good Luck.
Sep 26, 2007 | Televison & Video
Tv powers on and goes off after about 3 seconds
This set has a problem in the horizontal sweep circuit or in the main power supply. Most likely a failed component, and the set shut down to protect the rest of the circuit. If you know how to read a schematic diagram and how the circuits operate, then you will need a good multimeter and an ESR type capacitor checker to find out the short in this set. Sometimes the CRTs(Picture Tubes) will leak the coolent fluid out and onto the printed circuit boards. Also sometimes the convergence IC's can cause this problem, but if that is the case the small little pico fuses will pop also. If you have had no solid state or printed circuit repair experience, play it safe and call in a trained tech. Good Luck
Mar 17, 2007 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
895 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
