Back to:
Tags:
DVD Players
Generic problem for all DVD Players
Recording to dvd from sky + box
posted by roverboy on Feb 17, 2008
Sometimes the dvd recorder will let me record for about 10-15 minutes then goes into pause and the Copywrite Protected message comes up and will not record from that point.........Other times i get that same message from the second i press Record on the dvd recorder remote.........other times it will allow me to record a whole hour or two .......it is very unpredictable.
Any help will be appreciated....Thanks.
Comment by roverboy, posted on Feb 17, 2008
Daewoo DR-2100P
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
ipodfreek
Rank:Wiz Wiz
Rating: 85%, 24 votes
It sounds like you are catching the Macrovisiin copy protection on certain shows. I've personally never experienced this with my Panasonic unit while trying to record from television.
It is a bit weird. Have you checked their website to see if you can upgrade the firmware (internal programming) of the player?
Rating Locked! (?) roverboy has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Recording to dvd from sky + box:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
Panasonic DMR-EZ47V DVD Recorder / VCR...
i didnt know that you could set the time on the dmr-ez47v...
DVD Players
Want to connect a high-end DVD player via it's HDMI port...
DVD Players
How i can play pictures that recorded on Memorex DVD R
Sony RDR-VX515 DVD Recorder / VCR Combo
Oh i got this sony rdr-vx515 ok.. every thinks work fine.....
Coby DVD-209
Not able to play region 2 (uk) dvds. The player was...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
