Wiring diagrams for AO Smith motors are located on the side of the motor.
Looking at the back of the motor, at one o'clock there should be a GREEN screw, this is the ground, underneath it at 3 o'clock the other 2 screws are power, theses have no polarity so no wire color comes in to play.. so one power wire hooks to one screw and the other wire goes to the other screw. now to set voltage, there should be a little white tab at 5 o'clock., it has a pointer on it that when pointed up is high volts,( this is how its sent from the factory). to change this carefully pull out about a 1/2 inch on this tab and rotate it down and wiggle it back in, make sure it goes all the way back in, now its set for LOW 120 volts.
Remember you must prime pool pumps with A few gallons of water before you run it !!! not all motors are the same, soo if you can add a picture or a model number of the motor, it helps us Pro's give very accurate instructions.
Wiring for this type of motor marathon 3qt horse
MOST OF THESE HAVE THREE SCREWS ON THE BACK OF THE MOTOR. now looking at the back a (1) 0'clock there should be a green screw, this is where the ground wire goes. at 3 o'clock you will see. two more screws, this is where your power wires go, it doesn't matter witch one goes where. just make sure you ste the voltage switch to meet your needs, new motors out of the box are factory set 220 volts. after you install your pump PRIME IT WITH A FEW GALLONS OF WATER... Jay the pool pump motor repair guy longwood florida
WINDING CONNECTION OF SINGLE PHASE ELECTRIC MOTOR W/ 6 LEAD DUAL VOLTAGE.
Colors- red,blue.brown,black,yellow,green, no diagram on motor
