Question about Sewing Machines
CG-590 I cannot seem to get enough pressure from the foot when sewing. I am sewing denim, so thin fabric is not the problem. I have gone through the manual several times, but have been unable to resolve this problem. The machine sews a nice stitch, but the pressure foot does not pull the fabric in very straight and if I put the slightest tension on the fabric it sews in one place. Uhgggg.........plase help!
    Problem Solver:
  • 6 Answers
Time for a semi-industrial or Singer has the Empress Jean Sewing Machine - have not read reviews yet about it OVER time durability.
The Reliable 2000 is a mini monster - but the price also becomes a monster - there are many high dollar machines that will handle denium....
Since I didn't have that type of money for many years I would "hand walk" the machine throgu as much as possible - and ALWAYS have a very sharp fresh needle on - when it just got to be too much for my machine - I would hand sew pulling through with pliers - pushing up with one of my son's welding projects from school. Several machines I ruined because I ended up BENDING the internal drive arm. :( Ooopppsss
Posted on Feb 18, 2008
Machine will not move fabric along when trying to sew unless lifting pressure foot recently purchased recently at Hancock's store in Huntsville Al . Store closed down.
Your machine should be warrantied by the brand name, ie Singer, et al. Even if the store that sold the machine is gone, it should still be covered.
Check the manual for the presser foot pressure adjustment. Most machines have this which allows the user to adapt the pressure to the type of fabric being sewn. Thicker fabric will require less pressure than thin fabric like silk. Sounds like the pressure may be set too high.
Feb 09, 2017 | Sewing Machines
Need help with tension as thr stiches are puckering.
If the fabric is puckering when you sew, it is most likely because the thread tension is too tight. Make sure you are using a brand-new needle compatible with your fabric--using a 70 or 80 needle and a lighter weight thread may work better as a 90 or higher needle is big enough that it can stretch the fabric before penetrating it, causing puckering.. Puckering also occurs more frequently when sewing light-weight fabrics and may necessitate using a walking foot or a stabilizer to help give the fabric more body as it is stitched (wash-away stabilizer would probably be good when sewing washable fabrics). Another thing that may cause puckering is when the bobbin is wound at a fast speed. Slowing down when winding the bobbin will reduce the amount of stretch added to the bobbin thread. If it is stretched going onto the bobbin, it will shrink back up when it is stitched to your fabric. Also check whether your machine has a presser foot pressure adjustment. The pressure should be lighter when sewing finer fabrics, ie silk, and heavier when sewing thicker fabrics like wool or denim.
How to Prevent Your Sewing Machine from Puckering Fabric Howcast
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjcuq2nkIPMAhXlxIMKHVgUAqUQFgg1MAU&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Stitching is puckering on lightweight fabric SEWING IN GENERAL
All About Needles
Apr 10, 2016 | Sewing Machines
My serger will not sew light fabricssuch as light weight cotton or flannel
is it an industrial serger or for the home?
try different needles
also try adjusting the tension
Mar 11, 2016 | Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
The walking foot is too aggressive on material, causing it to claw rather than pull through nicely.
Walking foot may not work well on thin material or normal sewing, it is meant for quilting and is applied on several layers of material.
Oct 15, 2013 | Reliable 2000U-33 Mechanical Sewing...
When attempting to sew rather thin material the main presser foot has not enough downward pressure to keep the material from sliding around. This is on a Singer 111W. Works fine on leather etc. I thought...
This machine was not designed to sew THIN material. It is an upholstery machine and it will never sew thin fabric very well. You can try a smaller needle(size 16 or less) and shorter stitches. There is also an adjustment to raise and lower the walking foot located on the backside of the machine. It can be recognized by the wing nut holding it in place and that it slides up and down when it is loose.
sewman7
Jul 14, 2008 | Singer 7462 Mechanical Sewing Machine
Singer CG-590
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Apr 19, 2008 | Brother CS-8072 Computerized Sewing...
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Sewing Machines Logo
142 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
