Question about LG 50PX4DR 50 in. Plasma TV
High Definition Channels leave bar on top and bottom
I have a Panasonic surround sound system, high def cable box, and if I watch a DVD it is cut off on the top and bottom. When watching high def channels on Shaw cable, I get the picture in the centre, and blank top and bottom
    New Friend:
  • 60 Answers
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Posted on Feb 20, 2008
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Can't get surround sound for regular television. DVD sound is great but nothing on the TV channels either regular or HD
Only a digital audio source will produce surround sound.
What's the audio source you're using for TV sound? It shouldn't be the TV, but what IT's watching, like the cable/sat box.
Jun 08, 2010 | Panasonic Home Theater System System
How do I hookup LHT854 Theater System to tv if using comcast digital box? DVD player works fine with sound but but no sound if trying to watch tv.
most cable companies will provide you a high def. cable box for no additional cost. swap digital for high def box. run dvd into high def cable box and run hdmi output from cable box to lg input. hope this helps
Feb 01, 2010 | LG LHT854 Theater System
No picture but have sound
Make sure your not trying to watch a high def channel, you will get sound but no picture if tuned to a high def channel on a non high def input or cable box. Try a vcr or dvd player connected to the unit to varify the picture tube has not gone out.
Sep 25, 2009 | Televison & Video
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Digital Channels??
Direct from the Hitachi website - "Integrated HDTV Tuners: Hitachi's new top-of-the-line XWX series features built-in ATSC terrestrial and cable HDTV tuners to provide integrated high resolution, high-definition signal decoding." You will need a seperate HDTV tuner if you do not have cable or satellite and want to watch off-air High Definition channels.
Apr 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Display delay
This is unlikely Verizon's problem.
Does the delay occur with non-TV sources like DVD player or video games?
If so, that's the LG firmware.
Aug 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Panasonic SC450 Install
Yes You need a cable that runs from your cable box to the Home Theater System. If it is analog cable then you can use basic Audio Rca Cables from Best Buy. If You have a High Def box I would recommend using a Audio Fiber Optic cable from the box to the surround sound.
Best Buy 287
Apr 30, 2008 | Panasonic SC-HT75 System
Hig Definition
Sorry, no high-definition 1080 I........if you have RGB component
video input on your TV the best you can do is 480P or I from
component out on back of DVD..............T.
Dec 08, 2007 | Sanyo DS27820 27" TV
LG 50PX4DR 50 in. Plasma TV Logo
185 people viewed this question
