Question about Toshiba 40H80 40" Rear Projection Television
Sync gone nuts on non-progressive signals
Hello!
I have a Toshiba 40H80 rear projection HD set that we recently replaced (partly due to the problem I am about to describe). If the repair won't be tremendously expensive or difficult, I'd like to do so before trying to sell the TV. I don't expect to get much for it either way, but I figured it'd be worth the effort...
Some months ago, the picture coming from our non-HD Tivo went crazy all of the sudden. A faint, high-pitched whine could be heard and the picture tore completely to pieces to become, for the most part, colored lines. A few power cycles, etc., and it settled down. The problem began recurring with increased frequency, though, until it became the norm.
I discovered along the way that the progressive output and HD devices I had worked, though, on the component inputs of the TV. This would include an XBox, AppleTV, DirecTV HD Receiver and my progressive-output DVD player.
Basically, if the output was 480p or 1080i, I was good to go. This kept us using the TV for a while before buying a new flat panel last October.
The beast is now gathering dust and I want to get rid of it. I dragged it out a bit ago and, as before, found all the inputs working fine for the first few minutes... then the whine started, sync went to crap and the non-component inputs became useless again. Being off for extended time - I suspect heat is a factor - seems to make it ok for a bit.
Any thoughts on whether this is a difficult fix? Is there a capacitor possibly overheating? Bad solder joint of some sort?
I have the schematics for the TV, too, if anyone has questions.
Thanks!
- Aaron
  • amahler Feb 21, 2008
    Thanks! I'll open up the TV and start pursuing this and let you know what I find...
    Do you know offhand how many caps might be involved?
     - Aaron
    Sergeant:
    Champion:
  • 301 Answers
Try to replace all the 10mf16v surface mount caps in the next-hyper unit. it is the digital scan card which is why you could get the higher res output devices to work. you can replace them with regular electrolytic caps if you cut the legs short enough. i would recommend using 2 soldering irons to heat both sides of the surface mounted cap at the same time then let gently pull the cap off.
******make sure you check the polarity of all the caps after you are finished****
Posted on Feb 21, 2008
  • MATT BECKER Feb 22, 2008
    there are somewhere in the neighborhood of 10 caps or so. it ia a delicate job just make sure you don't rush it you don't want to accidentally damage any traces.
Toshiba 40h80 red light blinking
I would suspect the problem is in the convergence circuit---only one simple way to know---get at and un-solder all 18 pins on both the STK chips it uses.
Once they are free try to turn set on--if it comes on one of the chips is bad and both will have to be replaced.
Dec 05, 2012 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 Rear Projection TV flickering & blacked out
try converence board going out on your unit usally about 300 bucks to fix ok thx nick
Feb 08, 2008 | Toshiba 40H80 40" Rear Projection...
My tv toshiba 40h80 the red and yellow line up but the blue doint it moves up down but i caint get them to line up with the reds and yellow.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 19, 2010 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 TV - looking for original remote.
You can buy them at any of these sites:
http://www.toshiba.newremotecontrol.com/catalog_item.php?catnum=23306458
http://www.remotes.com/store/toshiba/40h80.html
or ebay
Aug 17, 2009 | Televison & Video
40h80 stk 392-110 ic
They are located on the signal board in that chassis they are side by side on two large heat sinks
Jun 18, 2008 | Toshiba 40H80 40" Rear Projection...
TOSHIBA 40H80 projection TV - no sound / no picture
it could be, that would be the first thing i would do to rule out I would first check for loose connections on the board.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 Setup Code
Stomper, there are at least 6 IC`s in your set, look on the bill and tell me which one(s) they changed. What is wrong with the set now that they have fixed the initial problem ? Once you answer these 2 questions I`ll have the info I need to give you a concrete answer.
Dec 04, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
40H80 Problem TV will not switch to non antenna inputs
Sounds like you have a bad tuner. It is not uncommon for solder joints to deteriorate over a period of time and loose continuity. If you are handy with a soldering iron, you can try to fix it yourself but I really recommend leaving it to a professional.
Dec 06, 2005 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
