Question about Oakley Thump 2 MP3 Player
Locked Out of MP3 Player
Help!!! I am locked out of my MP3 Player and I can't get the player to work. Each time I try and turn it on, I get the message "KEY HOLD!" and it immediately shuts off. I've tried repeatedly to slide the HOLD button toward the PLAY/STOP button as recommended in the manual, but to no avail. I can't get the player open. Is there something (anything) else "I" can do to get the player to work? Thx, Jack my mp3 player comes on for 3-5 seconds and then locks up. Ive tried reseting it but it does the same thing,and when i hook it up to computer the computer does not pick it up
  • 3 more comments
  • kennethb3 Feb 18, 2008
    when you hook it up to computer the computer does not pick it up
  • DFree7 Feb 23, 2008
    My Sansa Clip 2GB won't even turn on now. When I plug it up to the computer, it charges. When I take it out, the screen goes immediately blank. What do I do?
  • Yung Dre Aug 25, 2008
    i forget my lock code
  • Neel1857 Sep 03, 2008
    when i turn of the mp3 i get the key hold message and automatically gets shut off, kindly help asap
  • betzyah Jan 31, 2009
    apple ipod nano won't work. Walking in very cold, turned it off for awhile.
    Now I get nothing. Won't turn itself on.
  • 3,230 Answers
To reset OAKLEY THUMP, hold down the. Play / Pause button and the PREVIOUS SONG/REWIND button at the same time.
Good luck
Posted on May 31, 2009
    Sergeant:
    Champion:
  • 322 Answers
Try formating it then use itunes to reset it for you
Posted on Feb 17, 2008
My MP3 player won't turn on. It says key locked
its cause it is on lock on the top of your player there will be a switch that says "hold" flip and try again
Mar 24, 2010 | SanDisk Sansa e250 MP3 Player
"PLAYER LOCKED"
Allow unit to run dead.recharge battery.turn on and push reset(small paper clip in reset hole).turn off and back on .should now work.if not format and download new soft ware at http://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Nov 09, 2008 | Creative Labs Zen Neeon MP3 Player
Zen neeon lock switch doesn't work
Zen neeon, lock switch doesn't work. When I turn it on it shows a "PLAYER LOCKED" icon for a short time and then turns off.
Aug 30, 2008 | Creative Labs Zen Neeon MP3 Player
Key locked system shut down
On the top of the player there is a slider. When it is showing orange next to it your player is "Locked" so accidental button pushing wont mess up your tunes. Slide it over so it shows only white instead of orange and your player should be just fine.
Jun 18, 2008 | SanDisk Sansa e250 MP3 Player
Locked up sansa
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Apr 18, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Locked up
Look at the top of it, there is a switch saying 'hold' switch it in the opposite direction. The button is used so it does not turn on automaticly. When you have switched it, turn it on. It will work!
Apr 14, 2008 | SanDisk Sansa e250 MP3 Player
Diamond MP3 player Model DSM921SD-1G LECTEUR MP3/WMA PLAYER manufactured March 2006
there should be a hold button on top of the mp3 player...
turn that to OFF, that should solve your problem...
To turn the mp3 on press the play button and wait a couple seconds...
Sep 21, 2007 | Nefertech Diamond MP3 Player
Locked mp3 player
turn the hold switch (which is located on top of the mp3 player) to off... problem fixed :)...
to turn it on press the play button and wait 3 seconds...
Sep 05, 2007 | Nefertech Diamond MP3 Player
Most things with "Hold" button don't turn off the device. So I surspect there might be a deeper problem. You could try to check the battery see if it's still good. As last resourt, you could try to open it up and see if some how buttons are permanently pressed. You could even try to power it on without the switches. Most of this MP3 players (the small 1 that uses only 1 battery) are pretty much self contain so there shouldn't be anything wrong.
Sep 16, 2006 | SanDisk SDMX1 MP3 Player
My player is stuck at locked position
Try reformatting the memory while it is connected to the PC.
Aug 05, 2006 | Motorola Mobility M25 MP3 Player
Oakley Thump 2 MP3 Player Logo
440 people viewed this question
Top Oakley Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Oakley Audio Player and Recorder Expert? Answer questions, earn points and help others
