Scratches/Director's Cut/ I can not find the support to the little stove. The walkthrough I have said to look into one of the holes of a cement block in the other room which is the unfinished bathroom. The finger zooms into a block but there is no support for the little stove. I have come so close to the end of the game and I am very frustrated about this. I have even started the game over thinking I must have skipped over an important step in the game. Can you help me?
    Genius:
  • 3,587 Answers
Sounds like a gaming solution. You may wish to repost this in that arena, since this is on PC desktops..
Posted on Feb 17, 2008
How do I keep the seal in place on the door of the century wood burning stove.
Go to the local hardware, Lowe's or Home Depot and look for a product called "Gasketing Cement and Stove Sealer". Meeco's Red Devil is one manufacturer of the product. It withstands temps up to 2000 degrees. Cut the tip and run a moderate sized bead in the groove of the door or the front of the stove. Place the pre-cut NEW non-asbestos gasket in place and tamp it in lightly with your fingers. Then close the door to mold the gasket to the surface and don't disturb it until the sealant cures....ususally onernight or a full day while you are at work. Do not have a fire in the stove at the time.
Nov 22, 2014 | Century Heating The WHISTLER Wood-Burning...
Tip
Mending a tear in a poly tarp
Some holes in a poly tarp are able to be fixed easily while there will be other tears that might be grounds for tossing the tarp. For most small tears you can fix them yourself using some tarp repair tape and vinyl repair cement.
Before beginning gather up all your tools, a damp towel, a dry towel, utility knife or scissors, a role of tarp repair tape, a small jar of vinyl repair cement and a hair dryer.
You will want to find a clean place to lay out the tarp somewhere where there won't be any wind blowing your tarp around. If you do have to fix the tarp outside use weights or rocks to hold the sides down.
Find the hole or weak spot on the tarp and if there is any fraying use your scissors or utility knife to cut off the frays. If there are any bumps you will want to cut them out too.
After cutting off the frays you need to clean the area around the hole. The reason you need to clean it is because dust and dirt can make it difficult for the tape to stick. All you need is a little water and dish soap on a damp towel. Rub the solution onto the tarp at least six inches all the way around the rip, you can clean farther to be safe, but six inches should be enough.
Wipe off the soapy solution with fresh water and wipe dry the area with a clean dry towel. Repeat this cleaning for both sides of the tarp.
To close the tear, place your tarp repair tape over the hole and extend it out at least four inches on to the undamaged area. First cover the tear horizontally overlapping if you need more than one piece of tape. Once the tear is covered completely horizontally overlap the tape with a layer of tape vertically covering the hole and extending four inches on either side. Repeat for other side of the hole.
It is important that after you tape up the hole you need to let the tape sit for ten minutes to make sure that it has bonded properly. When you come back after ten minutes open your jar or vinyl repair cement and apply a generous amount of cement over the whole taped up area. To dry the cement grab your hair dryer and blow hot air on the cement until it is dry.
And there you have it a fixed tarp, granted not all holes can be fixed this way. But after its been fixed you can use it again like new.
on Feb 12, 2014 | Hardware & Accessories
Troubadour wood stove
Look up companies locally that can cut glass for CERAMIC glass only and get a rope gasket from a local stove company along with stove cement. Not the best solution and I can't guarantee it won't break again but that is the type of glass that would be utilized on a wood stove since the manufacturer is no longer in business.
You can also search on the internet for replacement parts for that manufacturer. It would be aftermarket but at least it would be the whole door.
Your other option is to replace the wood stove that takes the same size flue pipe as the Troubadour wood stove you have. Sorry not great answers but when these manufactures go under for a while its like trying to find parts for a studebaker. Sometimes you just have to make do.
Mar 16, 2014 | Home
My water bed is leaking, how can I stop the leak?
Firstly you must drain the water out, attach a garden hoseto the outlet and allow it to drain into the bathtub (you do not need to let itdrain all the way, just enough to allow you to lift the mattress) Second applypressure to the mattress to locate the source of the leak, when you have foundthe hole ***** how big it is, if it is of pinhole dry it and apply rubbersealant or rubber cement over it. Allow 30 mins or so to dry and you should beable to refill the mattress. If the hole is much bigger you should cut a patchfrom a bicycle inner tube that covers the hole. Make sure you overlap by atleast a quarter of an inch all the way around. Brush on a coat of rubber cementdirectly on the mattress. Brush a coat on the patch. Let dry until tacky and putthe patch over the hole. If you want, you can put alight coat of rubber cement over the entire repair.
May 29, 2012 | Furniture
I need the instructions for a Got Game Entertainment Adventure Collector's Edition Volume 1. The games are Rhem2, Scratches: Director's Cut, and Penumbra Overture. I need to know how to manuever...
Hi Peggy I do understand your frustration, I found game boomers.com they have walk-through,s for nearly every game.I have played scratches and got the walk-through from big fish. And,gamezebo has walk-through,s for some games to.These walk-through,s tell of the game play.I do hope this info is helpful.
Gabrielle.
Aug 07, 2011 | Toys
The disc is scratches
If the scratches are only fine then you can polish out these scratches.
You need to purchase a CD scratch polishing kit from the computer shop or from the Internet.
Follow the instruction on the CD polishing kit.
Mar 30, 2011 | Computers & Internet
Purchased 30 inch induction cooktop stove to
its ok to cut the laminate using the wood saw to fix the new one.be careful to cut the laminate.
Sep 09, 2009 | Cooktops
Scratches on glass stove
Is it glass or ceramic? there are special cleaners for ceramic tops check walmart, lowes, or where ever you bought that one they can tell you.
Aug 25, 2009 | Frigidaire FEF366 Electric Kitchen Range
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
