Question about Toshiba Satellite A135 Notebook
Toshiba satellite touchpad
All of a sudden while using the touchpad, if I tap on the touchpad, whatever I am doing either minimizes or goes to smaller size. Not every time, only about 1 out of 8 taps this happens. Also when the curser is in the lower right side of the screen, it now changes to a scroll type mode. I have had the computer a few years and suddenly this started happening about 5 days ago. I checked for new drivers and updated if it said to, also resent my computer to 15 days ago in case something got downloaded or something. Any solution on how to set this back to where it was?? Any help is appreciated.
  • StudyHard Mar 03, 2008
    yeah that happend to me aswell..suddenly the "switch" button on the dual mode touchpad [top right hand corner] is not making the touchpad light up to enable the other functions such as volume control etc, instead it just maximizes or minimizes the window
    does anyone know how i can solve this problem..its really irritating!
READ THIS POST NOT THE OTHERS. you can configure each of the four corners of the TouchPad surface to act as different buttons when tapped. These corner regions are called Tap Zones. to disable this feature goto control panel, mouse, device settings, settings, tapping, tap zones, disable tap zones.
Posted on Jun 29, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 7 Answers
I had the same problem. i went into the device options and under tapping i pressed "d" on my keypad- i had no idea what i was doing. anyway, it came up with a screen i had never seen before and i just ticked the box that said about switching to button mode. AMAZINGLY it worked
Posted on Aug 05, 2008
  • 689 Answers
Hi Terry
It seems you need to adjust the functions. There are several ways to resolve the issue. You may go to mouse option in the control panel. If your model has dual mode touchpad you can disable virtual buttons or you may reconfigure them accordingly. Also changing toucpad's sensitivity is another way of resolving the issue. If you need further assistance please post your question
Good Luck
Posted on Feb 17, 2008
I had the exact same problem start happening a few weeks ago. My windows kept minimizing on me when I would try to get the cursor into the search bar in the upper right corner. So far by simply hitting areas other than upper-right on the touchpad the problem has gone away.
Appreciate all the help, thank you!
Posted on Mar 10, 2008
Hey guest...solution # 2 was great for me...I thought I was having some sort of hardware problem. Great info. It would be nice if I was told of this before in some manual or something.
Posted on Mar 03, 2008
No, leave the functions the way they are, it just all depends on what part of the touchpad you hit, The top right corner of your touchpad, if touched, will minimize whatever window you have showing. The bottom right, will maximize, or bring it back from the toolbar. I wouldn't suggest changing anything.
Posted on Feb 25, 2008
2 Suggested Answers
SOURCE: toshiba satellite touchpad
2x + 4y = 0
2x + 9y = 6
Posted on Feb 20, 2008
I have a toshiba satellite pro and ever since i bought it whenever I go onto the internet after a few moments the screen will minimise itself. it normally does it if i click the mouse near to the edges of...
YOUR OPERATING SYSTEM MAY HAVE BEEN RELOADED WITHOUT PUTTING THE MANUFACTORS TOUCH PAD DRIVER BACK.WINDOWS WILL LOAD AN AUTOMATIC GENERIC DRIVER WHICH WILL LEAVE THE TOUCHPAD SENSITIVE TO CAPACITENCE FROM YOUR HAND. ALSO YOU CAN DOWN LOAD THE TOUCHPAD UTILITY FROM TOSHIBA TO ADJUST THE SENSITIVITY.
Aug 26, 2009 | Microsoft Windows XP Home Edition
Need Model specific touchpad drivers *EDIT*
Hey there, not sure if you tried this or not but this is the hardware setup for your laptop
seth
http://cdgenp01.csd.toshiba.com/content/support/downloads/util_hw_setup_25547A.exe
Jun 27, 2009 | Toshiba Satellite P105-S9722 Notebook
Touchpad
my laptop uses a Synaptics touchpad. In Control Panel, go to Printers and other hardware, then select mouse. Your touchpad device should be listed in one of the tabs at the top. For bigearlb: click settings, then my menu items list Tapping as one of the settings, and when I open it and on the right side is a check box next to Enable Tapping. Uncheck it and you should be good. For tmbc: Under device settings for your touchpad, click on Disable. that should do it.
Feb 10, 2009 | Toshiba Satellite M55-S325 Notebook
Touchpad minimizes screen
Double check your settings for the touch pad. It could be set to do that under one of the settings. Or something internally could have gotten jogged or internally moved. If that is the case there isn't much you could do unless you got someone to look inside of it for you.
Nov 06, 2008 | Toshiba Satellite A105 Notebook
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Screen minimizes when using the touch pad
If you touch the top right corner of the touchpad, it restores down the window you are currently in. The bottom right corner of the touchpad minimizes the window you are currently in. The bottom left corner of the touch pad brings up the start menu.
Nov 05, 2007 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A135 Notebook Logo
2,781 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
