Part number I have a phillips magnavox PR1903C125 and the power button and plastic mount is broke i am looking for a part number to replace it. any help would be greatly appreciated.
    Genius:
  • 1,665 Answers
Insert Manufacturer product model at following link tabs:
http://www.chsinteractive.co.uk/search.html?query=PR1903C125
Posted on Feb 17, 2008
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
Jan 23, 2013 | GE DBVH512GFWW Dryer
I got a Magnavox tv model number 27ms343s from a friend,but it didnt have a remote.The tv is locked and wont turn on by the power button,how do i find a code to set it up with my dish network remote?
We would be happy to help you with getting your DISH Networkremote to control your TV. Pressand hold the TV button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecodes for your Magnavox television; here some of the codes we currently have: 560, 829, 566, 761, 891, 828, 656, and 770.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this help and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 10, 2011 | Philips Magnavox 27MS343S 27" TV
I need a part number (or the part) for the Sharp TV, model number 32C241. I think the part is JBTN-0132GJKB but I can't correlate the number with a picture to be sure. The part I'm looking for is the...
I am unable to locate of picture of that part either but when Sharp says "power button" the on-off plastic push button is what that means. The cheapest I found it was on the mcm electronics website.
Aug 17, 2010 | Sharp 32C241 TV
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Plasma T.V
you need to contact phillips,magnavox consumer service which should be 1-800 number or look under www.phillips.com then type in km42010p.
Dec 23, 2007 | Philips Magnavox 27MS343S 27" TV
TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Phillips magnavox smokes
Replace the bad cap:
Capacitor C506 = 680pF 2kv = 483512247584 part number
Buy at tritronics by credit card: 800-638-3328
Oct 24, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
