Question about Brother FAX-575 Plain Paper Thermal
Ribbon empty Hello please help me how to: ribbon empty reset or replace FAX-575
  • 2 more comments
  • 2amor4 Feb 17, 2008
    Thank you very much bowdo for your help, but I just fixed myself again thank you.
  • svincent1372 Jul 10, 2008
    put new ribbon in machine . prints everything but the middle of page
  • Anonymous Aug 06, 2008
    how do i change the ribbon
  • Anonymous Dec 02, 2008
    ink
WHERE IS THE CARTRIDGE HOUSING
Posted on May 08, 2008
    Scholar:
  • 78 Answers
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Posted on Feb 17, 2008
Reset the ribbon on my 575 fax
No need for that. What is on the display ?
Oct 18, 2014 | Brother FAX-575 Fax Machine
Ribbon is empty in fax machine 575 what to do
Check if the thermal ribbon (ink) is finished . Open up the front panel and you will see the black film roll .
Sep 11, 2014 | Brother FAX-575 Plain Paper Thermal
How do I reset the Ribbon?
you don't reset the ribbon .. you have to replace it. it is called a thermal ribbon part number is Brother PC-501, or PC501 you can get it at office max or office depot or staples or Precision Roller for about $28.00
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Apr 12, 2014 | Brother FAX-575 Plain Paper Thermal
It says ribbon needs to be replaced or reset can i just reset and still use that ribbon
i got a new ribbon and it keeps saying ribbon empty reset or replace. i unplugged it for 30 seconds didnt do any good how can i fix this? it is a brand new ribbon
Jun 17, 2011 | Brother FAX-575 Plain Paper Thermal
HOW DO I CHANGE THE RIBBON?
You can use the below link that will take you to the brother FAQ website. Follow the FAQ to change the ribbon.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000500/000045/faq000545_001.html?reg=us&c=ca&lang=en&prod=fax575_us&Cat=7
Thanks,
Pat
May 13, 2010 | Brother FAX-575 Plain Paper Thermal
Ribbon say replace
you need to replace the cartridge or I rewind my cartridge. sane cartridge for 3 years.
Nov 06, 2009 | Brother FAX-575 Plain Paper Thermal
Can I reset the used ribbon to recieve a fax ready to print
You can rewind the ribbon. But the areas that has ben transferred from past fax's will be blank.
Jan 28, 2009 | Brother FAX-575 Plain Paper Thermal
Brother FAX-575 Plain Paper Thermal Logo
1,559 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
